billet serpentine conversion - alternator question
Hi folks
I have been looking at March Performance underdrrive systems. They tell me that I cant use themon my 76 because the alternator is on the drivers side. Is there a problem with moving it to the other side?
Has anyone sourced pulleys from another source?
Why wouldnt this work?
click here
1976
350hp deluxe crate GM engine
Hooker headers and side pipes
click here
1976
Hi folks
click here
1976
click here
1976
I installed one on my 75 (still there) and the 76 before I sold it. I had no problem with it on the driver's side. But, mine did not have the ac unit on it. But, call them and find out. I had to get on the phone with them and explain what I needed and they put it together for me. I even had an electric water pump on it that everyone said wouldn't fit.
Here's a pic. Maybe you can see something there you can use for reference.
I installed one on my 75 (still there) and the 76 before I sold it. I had no problem with it on the driver's side. But, mine did not have the ac unit on it. But, call them and find out. I had to get on the phone with them and explain what I needed and they put it together for me. I even had an electric water pump on it that everyone said wouldn't fit...
THANKS Folks!
You might look at a Vintage Air Front Runner. The Lower Pulley is very close to the Frame I didn't need to change anything but some have. Its Exspensive but its a very well done item.
Bee Jay
NBC3,
I can give you better pics when I get the top of the motor back together, but these are some pics of the original build that may help. Swapping the A/C and alternator locations enables you to completely access the passenger side of the motor. I've got the Vintage Air R134a kit that eliminates the factory A/C hump from the firewall. I will tell you that I had clearance issues with the Sanden A/C unit hitting the drivers side control arm when going over large bumps. Solved that by installing tubular control arms from Vette Brakes. Then I was plagued with the compressor pulley hitting the shock absorber mounting bolt. Solved that by cutting a 1/2 inch of it off. The P/S steering pump mounting may or may not be a challenge depending on the style of pump used. My pump had a hard line coming out of the rear that would contact the block and it put a slight angle on the pulley. I kept throwing belts until I finally figured it out and bent the hard line just a *tad* and that solved that issue. Yes, there were some issues with mine, but yours may bolt up just fine. I love my setup now that the bugs are out.
