502 head bolts
Old Jan 14, 2010 | 04:14 AM
Simmo's Avatar
Simmo
Default 502 head bolts
I only have a Mk IV manual and it says use sealant on the head bolts to stop coolant coming up head bolt threads. As far as I can see on my 502 block none of the head bolts enter the coolant. What should I put on the threads, anti-seize, oil or a moly lube?
Old Jan 14, 2010 | 04:58 AM
midyearvette's Avatar
midyearvette
no lube or grease of any kind as it could break out the block..(hydraulic)....no kiddin".....just wipe off with a thin coat of oil on the threads and wipe off very well, cleanliness is key here with "blind " holes......
Old Jan 14, 2010 | 07:45 AM
Simmo's Avatar
Simmo
Thanks for the low down
To 502 head bolts
