Best 502 crate engine for the money
I have a 1970 LS5 and thinking about changing out for a 502..and suggestions about best engine for the money?
I just want to put it in for the summer and have the original rebuilt and then put the 502 in another car.
ZZ502/502 hands down
All 502s are great motors.
I have an 502 HO in my 69.
The previous owner installed it. ZZ502/502 is more expensive, but worth the money.
not exactly a 502 ....but same price range w/more HP
http://www.ultrastreet.net/engines/540_realstreet.asp
There is quite a difference between those two....
Bryan
Is this who you got your new motor from?
I highly recommend him.
BTW the only reason its only $100 difference is it doesn't cost anymore to get the extra power really. The difference in the motors is the 620hp has about 1pt more compression and solid flat tappet cam vs. lower compression and hyd flat for the 571hp. Both motors get the big valve, fully ported GM 049 oval port heads.
If you stay with GM performance... there motor break down is...
572/620hp dollar per horse is 23.04 14,500
454h.o/425hp per is 14.10 6,000
zz502/502hp per is 18.07 9,100
All of these motors make great torque curves and there built by gm...
aj's motor is incredible and i believe with that builders knowledge and his advertised numbers it a better buy than the Gm stuff..
but if you care to deal with one of your local engine builders i would buy a 502 short block from gm ..install smaller port afr or dart heads and roller cam set up that suits your needs and build the engine with all forged internals and and make great hp/trq for the car this engine ends up in... i ended up with a 496 and about 733 hp 659ftlbs for about $10,000 and thats a 13 dollars per horse... just my thaughts...Rich
I drove a GM 502 / 450 ??? installed in a '67 'vert with a 5 spd ... and I was not overly impressed! That was a couple of years ago and I swore then I would have my LS 5 built right. Now its in the hands of GoFast and getting made into a 489!
Received 1,875 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Better read that warranty REAL close and see what it really covers and what you have to do to get it fixed.
JIM
JIM
5th Gear
..... put a 502 RJ in my 74 replacing the 'girl' motor..... direct from GM .... best thing I ever did.... took some doing but well worth it.... second hand motors are a crapshoot be cautious ....
