Lazy headlights? Here's a tip
Old Mar 2, 2010 | 12:41 PM
  #41
Ganey's Avatar
Ganey
Originally Posted by wcsinx
Silicone spray would be better. Silicone grease (what I use) is best. ...
You can get white lithium grease spray.
"Where ..."
The center port may be best as the double "piston" tries to seal center to bottom & center to top.
Old Mar 2, 2010 | 12:46 PM
  #42
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Originally Posted by zakim
Any photos as to where I should spray ?
I have asked this question too.. but n one seems to answer.. Maybe god knows..
Old Mar 2, 2010 | 01:02 PM
  #43
Ganey's Avatar
Ganey
Pics. by Dave, 71 Green 454
Old Mar 2, 2010 | 01:13 PM
  #44
MrGoFaster's Avatar
MrGoFaster
God listened and answered your prayers! ^
Old Mar 2, 2010 | 02:49 PM
  #45
wcsinx's Avatar
wcsinx
The only place I've ever used lithium grease is on window regulator tracks & rollers. Is it rubber safe?
Another thing I forgot to mention is while silicone is rubber safe, some silicone sprays actually use a rubber-attacking propellant. One way to check is to spray it on a styrofoam cup. If it eats away the cup, then don't spray it on any rubber.
the 3in1 brand silicone spray
is safe
CRC brand ...
is not
Old Mar 3, 2010 | 09:08 AM
  #46
CFD E59's Avatar
CFD E59
Great Tip. THANKS
Old Mar 3, 2010 | 09:17 AM
  #47
Ganey's Avatar
Ganey
I have used the white lithium grease in tube for many years on the rubber vac. AC/VENT/HEAT switches in several cars as well as reg. etc.
Old Mar 7, 2010 | 08:04 PM
  #48
psycho dad's Avatar
psycho dad
I wasn't sure what part needed to be sprayed, so I sparayed silicone on several moving parts, thinking "what could it hurt?" Both lights immediately stopped working. I just started laughing. My luck is so bad I could fall in a barrel of ***** and come out sucking my thumb.
Old Mar 8, 2010 | 10:44 AM
  #49
Crash80's Avatar
Crash80
You and me both....
Old Mar 8, 2010 | 11:18 AM
  #50
ajrothm's Avatar
ajrothm
Hey Ganey,
on tha pic you posted, are you spraying the lube in the square hole on the end or one of the vacuum hose ports?
I have a light that is sticking from time to time and getting lazy. I haven't started looking at it yet but I need to....sux at a cruise in and one light doesn't open without dicking around with it.
Old Mar 8, 2010 | 11:31 AM
  #51
Ganey's Avatar
Ganey
Alan
I restored mine.
http://forums.corvetteforum.com/c3-g...of-vacuum.html
To spray I suggest the center vac. hose port.
Old Mar 15, 2010 | 12:10 PM
  #52
Crash80's Avatar
Crash80
After having removed the passenger side actuator, I have decided there is no spray for a seal that fell out in pieces.... The rebuild is under way for both. Slowly but surely I am making this car new again, one piece at a time.
