70 Vacuum Can Removal Problem
Old Feb 22, 2010 | 01:28 PM
68/70Vette's Avatar
68/70Vette
Default 70 Vacuum Can Removal Problem
Yesterday, I removed the six screws that mount the big vacuum can to the back of the driver's wheel well. Three brackets attach the can to the wheel well; a bracket on top, in the middle, and one at the bottom. I removed all six screws. The can should have came out. It seems like something on its face (facing the inside quarter panel) is holding it in. Baffled. I removed one from my 68, and it came loose after undoing the six screws.
I've removed the power brake booster, the clutch bellhousing rods, and the engine, so there's no reason I can see it won't come loose. I looked in the AIM and saw nothing that's holding it in. Tonight I'm going to take a mirror and flashlight and try to see what's holding it?
Any thoughts? ???????
Old Feb 22, 2010 | 01:33 PM
71coupe454's Avatar
71coupe454
Seems like mine was a pain also.. think I found some screws hiding under crud and undercoating on the tire side of the wheel well...
Old Feb 22, 2010 | 05:01 PM
Alan 71's Avatar
Alan 71
Hi 68/70,
Did you remove the screws for the charcoal canister bracket thinking they were for the tank? The screws for the bracket on the tank that faces the inner fender are easy to miss.
Regards,
Alan
Old Feb 22, 2010 | 05:46 PM
68/70Vette's Avatar
68/70Vette
Originally Posted by Alan 71
Hi 68/70,
Regards,
Alan
Hmmm. Good thought. I'll have a look tonight. Actually I think I'll remove the charcoal cannister also, just to make sure. The entire area in their is pretty dirty, and is covered by respray from a previous owners repaint. I'll powderpaint the vacuum can if/when I get it out.
Old Feb 23, 2010 | 07:41 PM
Faster Rat's Avatar
Faster Rat
2024 C3 of the Year Finalist - Unmodified
Make sure to test it for leaks first
To 70 Vacuum Can Removal Problem
