Very simple qusetion wrench question
My cars is stored 100 miles away from me (so cant check the nut size) need to do the brakes on her,
What size flare wrench should i buy?
thanks
Eoin
thanks
Eoin
Depends on what lines you are taking off. If you are just replacing brake pads, you don't need to remove any. On the rears, you can just detach the hose/line connection from the trailing arm mounting, allowing you to remove the caliper from the rotor. To be safe, bring a couple of combination flare wrenches - 3/8 and 7/16 for one, 1/2 and 9/16 for the other. Oh, and don't forget some penetrant as well as a vise grips...ya never know.
Received 1,469 Likes
Cruise-In II Veteran
get one of the double ended 3/8 - 7/16 flare wrench.DON'T get a real cheap one. Good ones will run about 15.00 or 20.00, a lot for one small wrench,but worth it. I'm a Harbour freight hound, but some tools just need to be top quality, and this is one of them. the cheap ones will flex and round off the nuts. Give it lots of WD-40 or Kroil and let it sit for at least 1 beer. If your just doing pads, you won't need to remove any lines, but the 3/8 will work for the bleed screw as well if my memory is correct.
I wholeheartedly agree:
The only thing cheap flare wrenches are good for are rounding off nuts... just like channel locks and adjustable pliers!
I own a set of craftsman flares and have never looked back.
The pads are held by a large pin w/ a cotter pin so you do not need to remove the calipers to change pads. Get the brake piston retaining clips.
Bleeders should be 5/16, box end works.
