Vibration, from bad wheel bearing?
I've been fighting a vibration issue for a while now where at 52 mph I get a bad vibration. I've balanced everything twice and have to look somewhere else now.
If a bearing is going out, could it cause this kind of vibration at one particular speed?
I've checked for slop of bearings in the wheels but don't seem to feel anything excessive. Moving tire back and forth and top to bottom maybe 1/8 in. of play.
i would start by replacing the U-Joints on the main drive shaft and the half shafts. my vibration as around 45 and the main shaft U-Joints cured that. then after that i would have a squeal when i would make a right turn and the half shaft U-Joints cured that. just a thought if you have never changed them.
1/8" is a lot especially on the front.
Check the runout of the rim and then the tire.
I had one set that I had to go so far as to have the tires shaved to eliminate a vibration.
I have replaced half shaft U-joints but not drive shaft. I do feel a slippage sometimes which feels like differential clutch slip. Maybe it could be the drive shaft ujoint. I should probably check diff fluid also. I did fill with posi and new fluid maybe 25k miles ago though.
ps. you've checked front suspension parts like ball joints right?
I've been focusing on the rear since it feels like that's the origin of the vibration. I did make sure fronts were balanced and have actually rotated wheels to see if it makes a difference and it doesnt.
