Replacing Harmonic Balancer. What Else Should I Do While I'm There?
Old May 13, 2010 | 07:36 PM
Two Red Vettes's Avatar
Two Red Vettes
Active Streak: 90 Days
Default Replacing Harmonic Balancer. What Else Should I Do While I'm There?
'71 350/270.
I'm going to be replacing the harmonic balancer. Is there anything else I should take care of while I'm in the neighborhood?
Old May 13, 2010 | 07:37 PM
Gordonm's Avatar
Gordonm
Replace the seal also.
Old Jun 26, 2010 | 01:13 AM
Two Red Vettes
Should I replace the timing chain while I'm there, or doe this involve dropping the oil pan, etc?
Old Jun 26, 2010 | 03:07 AM
73StreetRace's Avatar
73StreetRace
You don't need to remove the oil pan completely, but it's easier if you remove the first 5-6 bolts in the front of the pan
and wedge a large flat screwdriver between the pan and block on each side between the first two bolt holes.
This will lower the front of the pan approx 1/8" . Then pry the cover forward at the top pulling forward till the cover clears the lower pan seal.
Before you reinstall the cover, trim the top corners (on the cover) pan seal rail, at a 45% angle, so it will slip into place with a new rubber seal glued to it, use sealer on the pan gasket and reassemble it.
I wrote that thread a few months ago :
http://forums.corvetteforum.com/c3-t...-pictures.html
While you're there, I would do it if I were you...
Old Jun 27, 2010 | 12:52 AM
ssenay72's Avatar
ssenay72
Definitely pull the timing chain and gears, mine were real sloppy. water pump if you need it.
Old Jun 27, 2010 | 02:41 AM
pauldana's Avatar
pauldana
you can always upgrade the HB to a Fluidamper type... love mine...
Old Aug 23, 2010 | 10:47 AM
zestay's Avatar
zestay
is this a good time to upgrade cam shaft as well? or do i need to pull the motor to do that?
Old Aug 23, 2010 | 11:11 AM
pauldana's Avatar
pauldana
huge huge big difference... huge
have you ever replace a cam?
off comes the carb, intake, valve covers, rockers, water pump, timing cover, timing changes, radiator, if A/C the condenser, dist, and I am sure I left out a bunch of stuff.....
then to put it all back together and adjust the rockers....
so no, unless you are willing to do a major break down...
P:-)
Old Aug 23, 2010 | 06:47 PM
zestay's Avatar
zestay
what do i have to take off to replace the harmonic balancer?
Old Aug 23, 2010 | 09:30 PM
redwingvette's Avatar
redwingvette
I replaced mine last spring. I had to remove the fan and all the belts. Then there was enough room to use the puller and installer. I also replaced the front seal at the same time.
Old Aug 23, 2010 | 11:41 PM
pauldana's Avatar
pauldana
Old Aug 24, 2010 | 06:55 AM
zestay's Avatar
zestay
Originally Posted by pauldana
radiator stays in ? sweet!
Old Aug 24, 2010 | 06:59 AM
zestay's Avatar
zestay
front seal.. can you be more specific ?
seal that goes around the crank ?
Old Aug 24, 2010 | 07:24 AM
L88Plus's Avatar
L88Plus
^ yeah, it's an interference fit into the timing cover. A lot of folks screw up the timing cover by trying to pry the seal out. It will work a lot better if you use a thin, wide block of wood against the timing cover and a long pry screwdriver to pop it out. Go back and forth from at least two sides, a more even pull helps prevent bending the cover. I've seen folks drill a tiny hole in the seal and thread a screw into it to give a better purchase for a pry bar, it's tough to get ahold of it with the crank in the way.
Me, I'd pull the engine and rebuild it as a stroker. There's nothing like a balancer replacement or spark plug replacement to begin the expensive quest for high horsepower
Old Aug 25, 2010 | 09:31 AM
zestay's Avatar
zestay
i do plan on building it into a stroker. i currently have a 350 crate from gm goodwrench in there.
im debating if its worth stroking that or getting a vortec 350 ( roller motor ) and stroking that but ive heard you have to do some grinding on the roller motors.. not sure if im down for all of that. .. and also heard its expensive to get a roller cam for a non vortec motor.... so im looking for the best bang for my buck options...
my step dads shop has the enjoine hoist and everything i need to pull and rebuild a motor which is 40 miles away.. might as well put on a balancer than drive it out there.. way cheaper than getting it towed..
Old Aug 29, 2010 | 10:28 PM
zestay's Avatar
zestay
grr all was going well untill i popped the radiator with the back of the mallet while i was tapping on the new balancer.. now i gotta replace the radiator.. oh well.. while thats out a new cam goes in.. =)
nothing like misfortune for a reason to upgrade !
Old Aug 31, 2010 | 03:26 AM
73StreetRace
That's a positive attitude.
Good luck with the next upgrade !
To Replacing Harmonic Balancer. What Else Should I Do While I'm There?
Old Aug 31, 2010 | 06:57 AM
ssenay72's Avatar
ssenay72
i have a rad in my driveway a few months old, come get it LOL.
Old Aug 31, 2010 | 09:30 AM
zestay's Avatar
zestay
What condition is it in ?
Old Aug 31, 2010 | 11:03 AM
ssenay72's Avatar
ssenay72
couple months old , i had a tranny cooler on it so a few fins are pushed aside but it doesnt leak and it was new when i got it. I jsut went with a dewitts alum setup. $100 and its yours. where do you live?
