Headers or stock manifolds?
How many of you run your basically stock C3 (small block) with stock exhaust manifold as opposed to headers? I am going to do a new exhaust system (true dual exhaust as stock) and am pondering whether or not to stay with the stock manifolds or go with headers. I have had headers on a number of my Chevy pickups, both small block and big block and found that a lot of them are not that durable.
If you are running headers what brand and what are your experiences as far as leaks/warps, etc.
well thats up to you as you say they don't last long well depends on what your buying there with jethots and cermics and stainless all out there then the good old just steel tubes that those do tend to take a beating. it all really comes down to what you want to spend i am a header guy if i can get headers on it their going on alot of ppl go cermic i perfer jethot then theres that bunch that goes stainless i am not a fan of stainless unless this is a show car that really gets driven as stainless holds a lot of heat and in my opinion leads to high underhood temps and if their polished there is always a point on a daily that their gonna end up being blued. these are my opinions thats all sure someone wil disagree with me but we all have our own thoughts
as far as leaks i have had the occosional collector blow out and a few flange caskets and a few lost header bolts in my day but if going headers a great investment is wired header bolts or theres is a kit that use a clip like a E-clip that the flat end snugs against the tube to prevent loosening. I perfer the wired bolts just think it looks a lil nicer with stainless header bolts and i nice twisted wire over the tube but hey thats just me.
brands just about all of them i have put on something lol.
is your engine stock? looking at the stock manifolds they don't look like they flow very well at all! i think they would hurt performance on anything more than a stock setup.
I am running C4 TPI manifolds which are like mini-headers. They have a true 2 1/2" outlet unlike stock manifolds. Kind of a compromise. Real headers can cook the oil in a C2 or C3 steering box due to the way they route.
Boy, I wish I had known about using the C4 manifolds before I put on McJacks shorty header which are an exact duplicate of the OEM manifolds. I bet they would have been a lot cheaper but McJacks do come with 2.5 inch collectors if you want and hook directly up to OEM duals for the OEM manifold with zero modifications and have large primaries. Very nice. How much were they and how big are the tubes?
C4 LT1 manifolds also fit, they are cast iron and have true 2 1/2" outlets. They do have a tendency to crack so make sure you take the shield off before you buy if you went that route.
SB C3s all have 2" outlets on the manifolds. (the last 2 1/2" ram horn was used in '64). The C4 TPI manifolds have true 2 1/2" outlets. They don't direct bolt to any C3 exhaust system because even the SB cars that got 2 1/2" exhaust had a 2" part until after it turned back under the car. I think I paid $75 for the pair, both lefts. I drilled out the AIR tubes and welded the holes up for no restrictions. They require ball and socket joints instead of the rams-horn cone in cone joint, but the exhaust shop can handle that.
Stock or Headers?
I was going to swap out my Manifolds to a set of Hedman or Flowtech Headers, but now I am considering leaving it as is. Mine is a city, Sunny day driver, I don't race it or anything. The sound is great now, and I am wondering will there be any benefit in changing to headers?
Or I am just throwing more $$ for nothing? I should also note, I RARELY get her above 3500 RPM, maybe when I am on an On-ramp for the Freeway, but thats about it.
I have a stock, with only a Performer Intake and 600CFM Edelbrock Add on. I just changed my stock Mufflers to MagnaFlows last weekend and I LOVE the sound!
