AFRs and center bolt valve covers
Has anyone had problems getting center bolt valve covers to work with AFR heads I have a set of AFR 180 elimonators and some comp cams roller rockers and my center bolt valve covers want work.
SOmeplace I've seen a conversion kit- has what looks like a cover with some bars across for the center bolts. Added advantage is it raises the cover so it'll clear roller rockers.
Do your AFR's have the duel pattern both Center and the 4 bolt pattern? My 180's do. My only problem was the raised rail made my Valve covers to tall.
The Rail is probably higher on Your Heads than stock just like mine. This dose to things it makes them harder to Leak and it raises the Stock height Valve Covers a bit to clear Valve gear. I'd guess a Stock Valve cover would work fine for you unless you have something out of ordinary.
