engine stand safe?
Old Oct 20, 2019 | 02:20 PM
HeadsU.P.'s Avatar
HeadsU.P.
Originally Posted by carnutsx2
Milodon sells a tray and bolt kit
Always check the date of the last posting.
Old Oct 20, 2019 | 07:48 PM
Little Mouse's Avatar
Little Mouse
Originally Posted by lars
9 year old thread - probably a dead issue....
rats Lars you ruined my day. I had a answer that only 12.9 alloy bolts would do. Lol
Old Oct 20, 2019 | 10:56 PM
'78CorvetteS.A.'s Avatar
'78CorvetteS.A.
Originally Posted by tfi racing
That is likely the strongest part of the whole deal.I would be far more worried about that chinesium tin folding up at the base,or a caster crumbling away while rolling it.
Chinesium.....had me rolling with laughter for 3 minutes!!! I love this forum, goes hand in hand with my Vette, it's an absolute obsession! Thanks for the laugh!👍
Missed the date, hadn't finished the whole thread! My bad!
Old Oct 21, 2019 | 12:22 AM
7t9l82's Avatar
7t9l82
Originally Posted by MotorHead
Wikipedia:
Chinesium, a part or combination of parts contains that looks exactly like a part you have seen before or looks good enough that you think it will work for it's intended purpose only to find out it rusts, breaks, causes injury, works for a few days then stops working, doesn't work at all when removed from packaging etc etc.
First discovered in GuangDong province of China it has become the China'a #1 export and it seems that regardless of how many houses are torn down because of drywall made mostly of Chinesium or toys and food that have unsafe levels of this substance for children, sales are on the increase as they have been for the last decade
Dont forget pet bowls, thier stainless steel has high radiation levels. I got pet teck bowls from weather tech. They are the only pet bowls with an nsf food grade for human ratings.i know that's off topic but if you love your dog as much as I love Bullet the Wonder dog, you should look into it.
Old Oct 21, 2019 | 08:42 PM
kossuth's Avatar
kossuth
Swapping bolts for studs you need to have the line bore at least checked. Commonly what happens is the bore changes due to the different clamping forces. As others have eluded to the torque specs for studs are higher. Additionally the axis of friction and resistance changes. With the bolts the twisting axis is obviously longer and will deflect more torque as the bolt gets tighter. With a stud it is much more stationary and the twisting axis is at or near the top. Additionally the clamping force originates closer to the surface of the head of the nut on a stud vs lower in the block when being pulled down by a bolt.
Ive seen where different fastener types required a rehone and other times everything is ok. Gotta check it.
