Muncie Transmission Castings
OK...I'm not thinking that this is a dumb question
I pulled the transmission out of my 73 which I believe is a Muncie based on the cover. The castings are:
Tail housing 3978764
Cover 3952648
Main housing 3925861
Tag on the cover 6271516WD
Bellhousing 3899621
Finally the POS clutch I pulled out I think was a 26 spline.
I'm trying to replace the tail seal and input shaft seal along with the clutch and before proceeding I thought I better identify the tranny so I make sure that I have the correct clutch as the seals didn't fit.
Cover 3952648
Bellhousing 3899621
Looks to be legit numbers. I think your main case numbers should be 661 not 861 for the last 3 digits. The 26 spline is correct also.
http://www.5speeds.com/casting.html
Thanks for the reply. I'll reverify the numbers, I was in a hurry this morning so I could have easily gotten them wrong.
So outside of a different rear seal, it doesn't matter if the tail section is from 32 spline transmission?
Also correct me if I'm wrong but isn't there supposed to be a input shaft seal on the back side of the cover on the front of the main case? The shop manual shows one but there isn't one there and I'm thinking it's why I was losing fluid. I tried to get one from the local parts store but it didn't fit (it was for a 27 spline transmission). If there is supposed to be one, would you know the part number or size?
Thanks again!
Thanks again!
There is no seal other than a gasket or some sealer on the front of the case. The part that the throwout bearing rides on is gasketed or sealed to the case. Other than that there is a seal at the rear output shaft. The 27 spline is the smaller output shaft used in the early Muncies. Yours should be a 32 spline output shaft.
