driver side window
Old Dec 10, 2010 | 06:19 PM
tim bob's Avatar
tim bob
Default driver side window
my 76 drivers side window is kinda jumpy up and down i took off door panel the only thing i can figure out is the motor is moving alot when windows moving the bolt i beleive that holds motor assembly is very loose i cant tighten it the bolt is just to the right of the motor im not familar with the way it operates. could the mounting plate be broke? or what do i need to do to correct problem thanks
Old Dec 10, 2010 | 10:05 PM
Peterbuilt's Avatar
Peterbuilt
Default Some kind of window malfunction!
Hi and welcome to the CF.
You will have to dig a little deeper to figure it out.
Try this "How to" and post back and someone will help you.
http://www.corvettemagazine.com/content/view/87/
Old Dec 11, 2010 | 07:55 AM
tim bob's Avatar
tim bob
thanks for the great info i will do this when i get a chance will post questions or results thanks
Old Dec 11, 2010 | 07:57 AM
jdp6000's Avatar
jdp6000
Try tightening it. No bolts should be loose. If its the one I think you need to remove the access plate. You have to get a wrench in behind to hold the bolt. All nuts/bolts should be tight.
Jim
Old Dec 11, 2010 | 07:59 AM
jdp6000's Avatar
jdp6000
Here is what it looks like from the other side. As you can see there are three bolts that hold the motor in place. All need to be tight or the motor gear will will slip eventually destroying your regulator
[IMG][/IMG]
Old Dec 11, 2010 | 08:50 AM
tim bob's Avatar
tim bob
yes theres two bolts mid way on the door those were alittle loose i tightened them then the one bolt on the bottom of of door right next to the motor its loose and will not tighten so theres a nut on the inside of door? thanks
Old Dec 11, 2010 | 06:05 PM
jdp6000's Avatar
jdp6000
Correct. There is a nut on the otherside. Its a bit of a pain to get to. There is a "U" bend in the regulator and the nut in buried in behind. You will not be able to ge a socket on it. You need a box wrench. Reach in threw the access door and fell around for it. You need to reach around the back of the power window motor. The long end of the box wrench has to face towards the front of the car....you need to slide it into the "U" channel over the nut and hold it while you tighten the bolt with a socket from the out side.
Jim
Old Dec 12, 2010 | 10:13 AM
Avette4me's Avatar
Avette4me
Cruise-In VIII Veteran
That's an excellent link. I've used it as well.
One thing they leave out is putting a bolt in the regulator so it doesn't try to shoot throuth the door or your eye.
See number 8 on this link
Old Dec 12, 2010 | 12:09 PM
jdp6000's Avatar
jdp6000
[IMG][/IMG]
Also make sure the three bolts you see holding that plate over the gear are tight as well.
To driver side window
