Rear Lower Shock Mount Options
Old Jan 20, 2011 | 10:48 AM
njfl's Avatar
njfl
Default Rear Lower Shock Mount Options
I need to replace one of my lower rear shock/strut mounts due to corrosion on the shock mounting surface. I've see that these appear to be discontinued from GM and at least two companies are manufactring them as aftermarket, one domestic US and one imported.
The original ones appear to be forged with hardened surfaces for the shock and strut mounts.
Does anyone have these aftermarket ones on their car? Are they re-engineered and equivalent/superior or should I just grab a used OEM one at the next swap meet?
Old Jan 20, 2011 | 01:48 PM
Rebelrob's Avatar
Rebelrob
Got mine from Willcox. They were very nice quality. Hopefully yours came out ok. I had to cut mine out.
Old Jan 20, 2011 | 09:45 PM
Rally68's Avatar
Rally68
Rebelrob is right...if you haven't yet removed the mount, you have more to worry about than where you get the replacement...
I purchased mine from Duntov and they were good quality. Don't forget the anti-sieze when you put them back together...
Old Jan 21, 2011 | 01:26 AM
njfl's Avatar
njfl
Thanks for the heads-up. They're out and I've done a few before too.
I'm not so much looking where to get them, but rather wanting to learn the quality differences between OEM and aftermarket.
Old Jan 21, 2011 | 07:56 AM
muskegonbrake's Avatar
muskegonbrake
Supporting Vendor
We have a removal tool for the shock mounts if you're interested, as well as the bolts themselves.
Old Jan 21, 2011 | 08:13 AM
MrJlr's Avatar
MrJlr
I don't think there's a big difference in quality...it's a pretty basic part...
The real difference is age...
Old Jan 21, 2011 | 08:17 AM
thegazman's Avatar
thegazman
Default thegazman
I did mine about three years ago. At that time my local Chevy dealer could still get the shock mount bolts from GM, but they were $119 each. I used the aftermarket $39.95 bolts and they worked fine.
Old Jan 21, 2011 | 04:05 PM
Roco71's Avatar
Roco71
I got mine last week from Wilcox and they fit great.
To Rear Lower Shock Mount Options
