Dyno results for Comp XE268H
Thank you for all the input here. I think my plan will be to get the torque converter first, then exhaust with 2.5 pipes and Magnaflow mufflers and see what that gets.
I will also price the labor for the gear swap and differential rebuild with the 3.55 gears. I will also go ahead and balance the drive and half shafts and replace the U joints as I get to them.
Ideal final 1st gear ratio for off the line performance is 10 to 1. You multiply your first gear ratio X your rear end ratio.
Turbo 400 has a 2.48 to 1 first gear x 3.08 is 7.64 to 1. This is where your at now.
A 3:55 gear gets you 8.80 to 1.
A 3:73 gear gets you 9.25 to 1.
A 4:11 gear gets you 10.18 to 1.
The XE 268 H operating range is 1600 to 5800. They say biggest cam with stock converter, better W/ 2000+ Stall.
Torque converter stall should be 200 RPM over low operating range of the cam.
The stock 400 convertor has a 1350 stall but the corvette is supposed to be 200 RPM higher.
Seems like the combination of stock converter and high rear gears are your problem. Replacing either one will help, Both would be better.
You will need to weigh your use. Lots of stop and go driving, lots of freeway cruising, Saturday driver with trips to the track on Sunday?
Just providing some info for you.
I lost the bookmarks, but there were quite a few posts about 4 speed automatics improving the ability to smoke the tires in cars with the lower-geared diffs.
1st gear 200-4r = 2.74 700-r4 = 3.06
An added advantage was the preservation of highway fuel economy that the overdrive provided.
A lot of posts have speed vs. RPMs info for the different combinations, along with the improvement on spinning the wheels. A little searching should provide info to help decide the right combo for you.
Mike
Mike
St. Jude Donor '09
Your cam is kind of a medium street performance cam and really isn't the problem. Gears would make a nice difference- as mentioned by 7t9l82 I'd go with 3.55s unless you plan to drag race or get an overdrive auto trans. If you can't afford rear gears right now a looser torque converter (w/ trans cooler) in the range mentioned by Vetterodder would really pick up your pull off the line. Anything higher numerically could create excessive heat in your trans on the highway with your current rear gears. Good luck.
Also, did you install the cam "straight up"?? If you had put it slightly retarded, you would have moved the power curve a little lower in the RPM range, IIRC.
Not real big on cam science, but I think that might have helped.
That being said, putting a good gear set behind you will really wake the car up! Driveability won't suffer much as long as you don't go too radical!! (4.11's or other such nonsense!)
hth
I am posting this data for others who are considering this cam and how it will result in rear wheel horse power and torque. Below is some data and a question at the end.
TH400 trans, 3.08 gears, base 160hp 350 bored .060, Performer intake, stock 76cc heads, Headman headers, 2.25 inch pipes with generic turbo mufflers, Stock HEI.
Baseline results: 178 hp
Added Edelbrock Performer centerbolt heads, Harland Sharp roller rockers.
Results. 203 hp
The a/f ratio was very lean at this point with the stock Quadrajet. I recalibrated the jets and rods per Cliff Ruggles advice,
Added Comp Cams XE268H and Crower CamSaver lifters.
Results are below 262 hp. That is an 85 hp gain from where I began. Thats about 60 rear wheel hp from the cam. I feel like I have corrected the lack of power this car originally had and think it can be officially a Corvette. It runs awesome from 3k rpm to 4.5k rpm. However, as fun as it is to drive now, it is still a dog off the line.
I feel like a Corvette should be able to do a burn out. The dyno guys told me I should have used Rhodes lifters for more torque. Too late for that. Do you guys think a 2800 rpm torque converter from Performance Torque Coverters would light things up?
Results. 203 hp
The cheapest improvement would be a higher flow dual plane like the weiand stealth with a QJ adapter plate.
TH400's are kind of a power sucker. shift kitted will save a few poneys
Results. 203 hp
Results. 203 hp
Location: Las Vegas - Just stop perpetuating myths please.
Nice work.
Congratulations and thanks for posting your results. This is big help to others on the forum looking at cam changes for horse power.
I'm sure u will get the gearing figured out but there are soo many options if u look at swapping even to another auto trans. My camaro has the 4L60 with a steep first 3.06 gear and overdrive too. Hi Po rebuilds are available for <$2000. Non electric version is the 700R4. Once you look at B&M shifters like the Hammer the ideas start flying.
Good luck and keep us posted,
cardo0
cardo0
A GOOD converter will net you WAY more ET reduction then a rear gear change....it improves your performance at any speed, not just off the line....The converter multiplies torque and helps with shift recovery. Also a converter affects your highway cruise rpms a lot less then a rear gear swap..... Spend the money on a GOOD converter and it will pay off huge.....
I know this is an old thread but I wanted to update it with my results.
The first change I made was a PTC 2800 torque converter for $300. It was tiny compared to the stock one. That helped the car with low end pick up but it would just barely chirp the tires. It added about 200rpms at 65 mph.
Next I bought a used 3.55 differential for $200. I replaced the side seals and used the yokes from my original unit. I also replaced all the U-joints which brought my total to about $330ish.
Wow! That's what I'm talkin about! It took both converter and gears to wake my motor up but it is finally as fun to drive as it looks. Thanks
I have a questions about your new converter. What RPM does it go to when you power brake it? And what did it go to with the old converter?
3.55 gears and a high stall converter automatic= Good Times!!!
Have fun,
John
Have fun,
John
#34
im running the xe268h cam with a tci breakaway converter 22 t0 2400 stall with 3.08 gears it will smoke the tires anytime i want it to 400 hp helps to and i can cruise at 70mph at 3000 rpms the trans is a th350
#35
Received 3,043 Likes
St. Jude Donor '05
Now recurve your distributor youll be even happier
#36
2500 rpm converter and a 700r4 Tranny.
You will thank me later.
Good low end,110 in the 1/4 mile, 20 mpg, and down shifts into 3rd at 110mph when you jump on it.
That's what I'm running.
R~
R~
#37
Had the XE268H in my previous engine (now XE274H in 383 stroker); 205 rwhp due to lack of compression, but a ton of torque!
However: with stock TH350 en 3.55 gears I'd do burn-outs no problem.
#38
I ended up going with a 2800rpm 9 in converter from PTC and 3.55 rear gears. The car takes off like a sling shot.
Next spring I will be putting in a 200-4R
