Can you help with 383ci engine build?
Hello
Well, finally I am in the position to build my new 383ci engine for my 1980 but, unfortunately to have the space to build this engine I had to send my Z on holiday to a lonely industrial storage place.
I have never built an engine before, but I am sure that I can do it and hope that you will be able to point me in the right direction.
Here is the parts list:
SHORT BLOCK:
Block: http://www.summitracing.com/parts/NAL-10105123/
Crank: http://www.summitracing.com/parts/SCA-435050L/
Balancer: Pro Street 6.75” Internal
Fly Wheel: http://www.summitracing.com/parts/MCL-460260/
Rods: http://www.summitracing.com/parts/SCA-26000716/
Piston: http://www.cnc-motorsports.com/produ...99&CtgID=16047
Cam: Comp Cams. Billet Custom grind 282/288 advertised duration, 230/236 duration @ .050 with lift of .591 intake, .593 exhaust with 1.52 rockers on a 111 LSA.
Timing Chain: http://www.summitracing.com/parts/CLO-9-3145A/
Timing cover: http://www.summitracing.com/parts/CLO-9-225/
Oil Pan: http://www.summitracing.com/parts/NAL-12557558/
Pan Gasket: http://www.summitracing.com/parts/FPP-1886/
Oil Pump: http://www.summitracing.com/parts/MEL-10552/
Lifters: http://www.summitracing.com/parts/CCA-850-16/
Instalation kit: http://www.summitracing.com/parts/CCA-08-1000/
Main bearings:http://www.summitracing.com/parts/CLE-MS909H/
Rod Bearing:http://www.summitracing.com/parts/CLE-CB663HN/
Flywheel bolts: not yet
Balancer bolt: got ARP one
Clutch:http://www.summitracing.com/parts/MCL-6911-07/
TOP END:
Head Studs: http://www.summitracing.com/parts/ARP-134-4001/
Heads: http://www.summitracing.com/parts/RHS-12024/
Head Gasket http://www.summitracing.com/parts/FEL-1010/
In. Valve: http://www.summitracing.com/parts/CCA-6009-8/
Ex. Valve: http://www.summitracing.com/parts/CCA-6012-8/
Valve seal: http://www.summitracing.com/parts/CCA-529-16/
Installation tool: http://www.summitracing.com/parts/CCA-5334/
Spring locator: http://www.summitracing.com/parts/CCA-4696-16/
Spring Shims: http://www.summitracing.com/parts/CCA-4757/
Springs: http://www.summitracing.com/parts/CCA-26120-16/
Spring retainer: http://www.summitracing.com/parts/CCA-795-16/
Valve locks: http://www.summitracing.com/parts/CCA-613-16/
Guide plates: http://www.summitracing.com/parts/CCA-4808-8/
Rocker studs: http://www.summitracing.com/parts/ARP-100-7101/
Rockers: http://www.summitracing.com/parts/CCA-1604-16/
Intake Manifold: http://www.summitracing.com/parts/EDL-71041/
Intake manifold gasket: http://www.summitracing.com/parts/FEL-1206/
MSD Ignition: http://www.summitracing.com/parts/MSD-8362/
Distributor Dyna Module: http://www.ecklers.com/product.asp?p...1&dept_id=1785
Fuel pump: http://www.summitracing.com/parts/ACF-41240/
Fuel pump push rod: http://www.summitracing.com/parts/CCA-4607/
SHORT BLOCK:
TOP END:
You do realize the crank is externally balanced ? They make the same crank internally balanced you are going to have to change it
http://www.summitracing.com/parts/SCA-935050L
By the book How to Build the Small Block Chevrolet by SA books, the only book you need
I do have the How to build SBC books and found them very useful.
Also, I spoke to Scat Tech. Dep. before I bought the crank and was told that I should be OK to internally balance the crank.
(I will be pretty PO if it turn out to be externally balanced crank)
Guess, I will find out 100% when the assembly goes for balancing!?
Click on your crank link and look beside "Engine Balance" then click on my link and look at the same
I would swap out the Single plane for a Performer RPM too. Almost the exact same port size but the Team G is a 2800 to 7200 RPM intake with an adapter plate needed. The Performer RPM is a 1500 to 6500 RPM intake with the correct mounting flange. Your hydraulic cam is probably a 1800 to 5800 operating range and you will probably never see over 6000 RPM. Much better match for your specs. It you were running a solid roler I could see it.
Hello,
Point taken, I will exchange the crank for this internally balanced one http://www.summitracing.com/parts/SCA-935050L
Thank you (Better safe than sorry)
I will need to stroke clearance the block so to get the feel for it I started cleaning the oil passages.
How far do I go with the grinding?
Do I just smooth out the passage?
It took me 2 years to get this far.
I will be taking pictures of the build, so hopefully more people will get the courage and assemble their own engines.
If I can do it, everyone can!!
Paul
On the other hand you might be able to find a externally balanced flywheel and balancer locally.
My previous 406ci was externally balanced and it made it to 550HP @ 6000RPM. It had a solid roller cam though. My new 427ci is a little smoother and it will rev to 7500RPM while I wouldn't go past 6500RPM with the 406ci
It has to be balanced correctly or you will have no end of trouble. The best route to go is internally balanced. Best dual plane IMHO is the RPM Air Gap
Crank up the vol
Crank up the vol
I will swap or buy a new crank, but I want internally balanced rotating assembly!!
With regards of the intake, I will go with the single plane for now and if it turns out to be a dog I can always replace it with Performer RPM at a later date.
(Also, my car is 4 speed manual so the single plane may work OK, I shall report back once this engine is running in my car)
...I would swap out the Single plane for a Performer RPM too. Almost the exact same port size but the Team G is a 2800 to 7200 RPM intake with an adapter plate needed. The Performer RPM is a 1500 to 6500 RPM intake with the correct mounting flange. Your hydraulic cam is probably a 1800 to 5800 operating range and you will probably never see over 6000 RPM. Much better match for your specs. It you were running a solid roler I could see it.
http://www.summitracing.com/parts/EDL-7104/
Nothing wrong with the single plane, that's all I have been using from as far back as I can remember
Talk to Summit and see if they will give you a break on shipping or anything since obviously you were steered wrong by the brain surgeon at Scat
One way, or another I will have the Internally balanced crank.
Leaving the intake aside for now, how far do I need to go with the grinding job?
Just a little tickle or a proper grind?
I don't know anything about your crank shaft. But your rod bearings say NON chamfered. So when you look at the crank rod throws see if they are machined square or with a radius
Clevite rod bearings are marked top and bottom.
I recommend buying rotating kits. That way everything fits together
So the rod bearings are wrong. Those shorty headers are pretty worthless and they might actually be smaller than the head ports
Just checked and measured the ports on the heads and the headers and they are IDENTICAL 1.35”x1.40”
The headers are McJack shorty headers. http://www.vetteheaders.com/servlet/...orvette/Detail
Just debur any rough edges or anything sticking out you don't need to overdo it.
That is a cast crank and I had a cast Scat 9000 crank a while back and was able to use the cheaper Clevite P series bearings so make sure you use the correct bearings.
See if you can get the same guy at Scat on the phone he should know
Just polish up the lifter valley and passages, you don't really need to remove much material, just make it shiny. The object here is to make a surface that the oil will not cling to, so it just slides right on down back into the pan.
Scott
Hi, I really need your help on this one.
I spoke to Scat Dealer here in the UK and he is happy to take my crank and exchange it for the 935050L crank.
BUT,
He is saying that it will be lot more difficult to balance the 935050L crank with the 6” rod, because the counter weights in this crank are smaller and he is advising against adding weight to balance the crank.
Apparently I will be better off to keep my existing crank and take away weight to internally balance the crank.
Something to do with BOB weight?
This 935060L crank is asking for INTERNAL front balancer and EXTERNAL Flywheel
This is link to the Scat catalogue PAGE 2 : http://www.scatcrankshafts.com/catalogs/2011/24-45.pdf
935050L *Balances at 1830 to 1850 grams with std weighted flywheel , neutral std balancer & one piece mallary in counterweight 1
Help
BUT,
Help
