Factory Auxiliary Cooling Fan-1979
My car does not have this option (see diagram below). I presume because it does not have A/C. Nevertheless it seems like a good idea. I do know that the temp sensor is in place between the back two cylinders on the passenger side. I can feel the male connectors.
I guess the basic question is: What was this fan designed to do? I have been fortunate not to experience over-heating problems even in July. Was the fan for high-heat, A/C load, slow traffic conditions? Has anyone ever seen one of these units? How do they fit on? I am contemplating installing it if I can find one in a salvage yard. If none can be found, will aftermarket units do the same job attached to the stock sensor and wiring?
http://temp.corvetteforum.net/c3/paul79//auxfan_002.jpg
Re: Factory Auxiliary Cooling Fan-1979 (paul79)
They are switched on by the temperature sensor mounted on the right
side of the engine. Are not switched on when the A/C is turned on.
On cars originally equiped with this fan, there is a trap door on the
bottom of the radiator shroud which opens to let more air in. The
fan is mounted to a bracket with three arms which bolt to the shroud.
Fan is standard on A/C, L82 1979's and L82 1980's.
Paul;
The aux fan was only used on L82's with A/C. My car has one. It is designed to come on at 238 degrees. I have never seen my temp get even close to 200 degrees so I don't think mine has ever come on. It mounts to the fan shroud on the engine side of the radiator.
My daughter has my camera right now. When I get it back I will take a picture and send it to you.
Re: Factory Auxiliary Cooling Fan-1979 (Pete79L82)
Thanks Guys. My car has never seen much more than 210 - July on the highway - so I guess this is non-starter for me. There are other places to spend money ;) .
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Paul, I have one for sale at this time.
"This is a real nice '78-82 L-82 auxillary cooling fan ready to bolt in to your radiator shroud. Drill the three holes in the factory marked areas and bolt it in. $75.00 shipped lower 48. "
I may be wrong and I think it has been discussed here before, that not all L-82's had the trap door in the fan shroud.This is optional in my opinion. JIM
Thanks JIM
_______
Thanks JIM
_______
Re: Factory Auxiliary Cooling Fan-1979 (PROSOUTH)
Jim,
Appreciate that. I do not know if I have a trap-door or not. What does it look like? Will check tomorrow late. Do you have the wiring harness to go with it?
Mine has the fain. It was like a "Eureka" moment when I looked in there and saw -- much to my surprise -- an electric fan!
It already saved my butt at least once, before I learned I had a weak fan clutch. And yes, in South Texas we are well into peak cooling (and yes, A/C) weather.
Just to rub it in, we'll be taking out the JetSkis tomorrow....
St. Jude Donor '05
Re: Factory Auxiliary Cooling Fan-1979 (page62)
I did not install this fan in my car. My Vette is a L-48. I purchased this off of a low mile L-82 car and stored it years ago. I am not familiar with exactly how it works with the switching. However there is a wire running from the fan that plugs in on the right hand side of my engine compartment. How it actuates I don't know. I assumed it was turned on by the A/C and or a temp.switch that was also in the line.
Anyway, This fan works good and I no longer need it.$75.00 shipped as stated. JIM
http://<a href="http://images.andale...ts_034.jpg</a>
http://<a href="http://images.andale...br /> <br />
Thanks JIM
[Modified by PROSOUTH, 6:19 AM 4/22/2002]
Thanks JIM
