C5 wheels on my C3 75 sense check
Can I dig up this topic? I have an option on some decent C5 wheels; 17" front, 18" rear.
I'd like to understand all that comes with using adapters, so here goes: Why would I need to replace the studs when using adapters, but not when using, say, aftermarket TTII's ?
Received 19,220 Likes
'20-'21-'22-'23-'24
Coming from a C5 guy, those chrome wagon wheels look great on your '75. Very good choice.
Sorry for the delayed response, I had to pull the wheel to take the pics. To answer the questions and comments:
- The tires are Firestone Firehawk Z rated Run flats.
- Thanks for the advice on the studs. I didn't think of that. After I put the suspension parts on, and before I add the HP's I will replace them.
- The pics of the adapters are below.
Let me know if there are any more questions.
Have a good one!!
Tim
Have a good one!!
Tim
Thanks!
Looks like it's been a while so let's try to revive this thread again. sorry but I'm a new Corvette owner and I got a hold of some C5 rims at a really good price. I've got my 3 inch adapters the rims are the 17 fronts 18 rears. decent 3 inch aluminum adapters from Amazon, problem is I seem to have about 1/16 of an inch of space between the rim and the adapter and I wanted to get a little advice. should I get a small spacer to put behind ,should I trim the edge of the adapter down or maybe an option that I haven't thought of I'd love to hear what you guys have to say. 1979 L3, 3 inch adapter. I'll add a photo is soon as I can figure out how
the most important thing is use concentric adapters.
these are 2.5" adapters all 4 corners.
that adapter design/configuration with the radius is stopping the wheel from seating properly.
Do not use that, I would definitely return, and get adapters that do not have that radius present.
Those don't have the correct bore size.
Stock is a 70.3 hub diameter. You may need a custom adapter to work with the wheel your using.
http://www.motorsport-tech.com
Navigator
I know it has been years for this thread, but it came up in wheel spacer and adapter searches.
If other folks are looking for spacer/adapter sizing for various generation Corvette wheel fit on C3s, I posted some helpful technical documents and a visual calculator link at https://www.corvetteforum.com/forums...post1604241234
The following 2 users liked this post by KevinHVettes:
Adollarwodbnice (04-15-2022),
chevymans 77 (10-31-2021)
