I have placed several papers at Corvettefaq.com that should be very helpful with information on the Saginaw model P power steering pump. This pump was used from 1963 through 1982 on the Corvette.
The good news is that this same pump (with minor updates) is still being manufactured today. The P-Pump Parts Repair and Replace paper outlines where to get parts and components.
There are also several papers which should help in diagnosing leaks and also blowup pump pictures.
Jim:
Sure.. now ya tell me after I've finished mine.. :jester :jester (kidding) Thanks for all you've helped me with Jim. You are the "PWR MAN".. the "STEERING SENSEI" in my book!! Keep up the great work.
Ed
Jim is definately the sensi of steering...he worked at Saginaw Gear...in the steering department, right next door to the tranny department, next door tothe steering column department, next door to the rack/pinion department....
and all the guys had lunch together....;-)))
SO if anyone needs ghuru info...it's him....
so HI Jim....from across the land here in sunny Florida, land of rack and pinion conversions which work fine....
