OK, engine guys...what am I doing wrong?
gen 1 sbc, 2 bolt, 76' vette
vortec heads, valve job, springs, seats
GM performance aluminum vortec style intake
lunati bracket master 2 hydraulic cam and lifters, with double timing chain
# Advertised Duration (Int/Exh): 284/284
# Duration @ .050 (Int/Exh): 218/218
# Gross Valve Lift (Int/Exh): .458/.458
# LSA/ICL: 110/106
# Valve Lash (Int/Exh): Hyd/Hyd
# RPM Range: 1500-5200
sanderson block hugger headers
MSD street fire spark plug wires
accell shorty spark plugs
rebuilt Q-jet 750 cfm carb
Super T-10 reuilt less than 8,000 miles ago
3.08 rear
new wheels and tires, but over all diameter is the same
It's broken in, and I've ironed out all the kinks, runs great...and while I realize that it's the 3.08 gears that's killing me...I just sorta expected a bit more kick to the but dyno than what I'm getting. Any ideas? Tips? Suggestions? Thanks in advance, guys!
As mentioned above, have you recurved your distributor, it will make a big difference.
I got my car weighted at the local dump, and it clocked in at around 3,200lbs.As for the intake, I don't know the part number, but it's a dual plane, high rise aluminum vortec style intake.
The main reason I went with this cam is because of the lift restrictions on the vortec heads. People have said that .470 is ok, but others say that .460 is as high as they would go. I didn't feel like this was a big cam, and still don't...but then this is all new to me. I also didn't want a cam that made top end power, as I don't plan to spin the motor much past 5 grand, ever. Well...at least not till I can afford an LS1 swap...
I will check the timing again, but I'm pretty sure I've got that all dialed in. Just for *****, though, what would you guys say my curve should be?
Also, what do you mean by not high enough comp for the cam?
The wimpy L-82 has a 222/222 with mid 400 lift and it only put out about 225 rated hp. So you can't install a lessor cam and expect anything in the way of hp gains.
You have to take gkull and skunk and those guys with a grain of salt when they talk about camshaft "size". They build ridiculously powerful racing motors, and really serious street/strip machines; these little street car cams seem kinda wimpy compared to what they are used to. Kinda like spicy food. One person takes a bite of chili and says:
"Hmmmm........it's not without it's charm........suitable, perhaps, for small children and the elderly....."
The next guy takes a bite and starts screaming:
"Kill me!! Kill me now!! I can't take the pain!!!!"
gkull and the rest of you serious engine guys, please don't take this as any kind of an insult, it's just that everything is relative.
Scott
On my stock 74 I have 12* initial plus 24* from the mechanical advance for a total of 36*, my vacuum advance ad's another 16* for a total advance of 52*.
I fired it up expecting something great and I was disappointed! I drove it around for a year or so like that while plotting my next move
The L-82 cam has very slow ramps...... It's just GM junk intended to help the motor last 100,000 miles
