Am doing a front-end rebuild/rehab on my '71 coupe. Have noticed that the lower control arm shafts appear to be bent. Thing is, they're both bent at the same point, and bent about the same in the same direction. Hard for me to believe that this is normal.
Appreciate any and all comments...
How about it Alan71??
Willcox Guy??
Thanks all,
71scgc
I assume you mean the rear, and yes, they frequently are bent as a 'fix' for worn bushings or worn diffy yokes which allow the wheels to lean in on top,
Willcox Guy??
Thanks all,
71scgc
mrvette- this is on the front end. But yes, it is the rear end of the shaft that has the bend.
Ricky- not sure you could see the bend in a photo. It's only really noticable if you sight down the length of the shafts.
Thanks!!
Thanks!!
That doesnt sounds right..
The bracket (shaft) that holds the trailing arms to the crossmember should be absolutely straight, oyherwise one will get funny forces on the bushings as the trailingarms/suspension moves.
Are you shure that its not worn bushings makin it look like teyr not straight?
A shame youre not living in Sweden then i could have donated my old trailingarms and brackets to you.
They do take a beating sometimes, but to bend them takes a pretty good hit. The shafts are not symmetrical and looking from end it might be difficult to tell if they are straight. My guess is someone bolted them up wrong. They only fit correctly one way. If bolted up wrong, it will bend them. Is the bend up and down or sideways to the bolt holes?
Thanks for the input thus far! Again, this is on the front lower control arms (A-Arms) not the trailing arms.
Wombvette- The shafts will go on either side, but they can be flipped such that they would be installed "upside down". As far as the bend is concerned, it is at the back end i.e. the single bolt end of both shafts, and they both bend to the right when viewed in an "as installed" position (viewed from the single bolt end to the double bolt end). Neither control arm is damaged, however, there was more alignment shims on the left upper control arm than the right, and the shaft that was on the left is slightly more bent than the rightside shaft. This car did have very minor body damage from a right side impact when I bought it. Given the minor damage, I can't imagine it took enough of a hit to bend these shafts, but you never know...
Where's New Hill?
Hi scgc,
I took a close look at my lower shaft and can't see anything that could be called a bend. As stout as those shafts are I'd think it would take a real whack to bend them.
It's odd that they're both bent... that makes it seem like it was an alignment? tweak? Or, a straight-on hit on a curb at 150 miles an hour?!?!
Regards,
Alan
I am also rebuilding my front suspension and have found two of the front A-arms shafts bent slightly. I believe these were bent during a previous bushing install. I have been able to mount the shafts in my vise, heat up the bend with a propane torch and put some weight on the bar or use my dead blow rubber mallet to take the bend out. With a propane torch it will not get cheery red hot or even close so I don't believe there are an down sides to using this method.
I would try this and see how much of the bend you can get out.
Wombvette I agree, regardless of cause these shouldn't be bent.
Alan71- Thanks for checking the "reference car" on this!!
To all- I appreciate the input!!
In closing- New shafts will be ordered, just gotta decide from where. OEM's are out there, but $$$. Thinking MOOG replacements. They come in a kit with bushings and bolts...I have bushings and bolts!!!
Dammit!!
71scgc
