transmission to bellhousing torque?
these manuals i own really really suck for engine/tranny work.
anyways, whats the tranny to bellhousing specs? this is for a 4 speed manual.
thanks.
thanks.
The '66-'82 Shop Manual says 30 lb-ft for the Flywheel Housing. It also says a 4-speed transmission case to clutch housing is 52 lb-ft. Why they don't call it the same thing, I don't know.
That's what it says in the specifications section, page 15-13 under Four Speed Warner...
Reread your post...the 30 lb-ft is for the flywheel housing to engine...
The 52 is tranny to housing, what your looking for.
Understand, just typing what's in the book...
Three & Four Speed Saginaw Transmission Case to Clutch Housing Bolts 75 lb-ft!!! How 'bout them apples...
No Munchie #s...hmmmmm
Front bearing retainer,side cover,tailhousing and bearing plate...
Bellhousing to engine block torque is not that critical,I have never used a torque wrench for it on any vehicle,but it feels like 45ish ft/lbs should be plenty...
