intake manifold restoration
These are before and after pics. I had no reason to take the motor apart as it was running fine. I did have to install a new raditor, timing chain, etc. So, while I was in there ...
The after pic was taken about half way through the "make-over" No matter how you do it, it's a lot of work. If you want a "show quality" as you put it, then I personally pull the engine and start from stratch.
Here's 2 tips to remember if you do decide to pull the intake for whatever purpose: pull the distributor cap to one side (or remove it and the plug wires entirely) and engage the starter to have the distributor rotor pointing right at the carb...doing so will insure that installing the distributor afterwards gets it back where it belongs; not exact, mind you, but close...you'll still need to check your timing because lining it up by eyeball won't be exact. The rotor doesn't HAVE to be pointed front, it can be pointing in any arbitrary direction that makes it easy for you to remember how it needs to go back together to get it close to refire the engine.
The second thing is to remember to coat the threads of the intake bolts with a sealer like Permatex #2 to prevent oil and coolant leaks as they don't go into blind holes in the cylinder heads. Clean off all the old gunk if re-using the OEM bolts.
Like billla, I've done these tasks so many times over the years that it's become second nature. It's hard to remember how daunting a task this can be to someone who's never done it before. At least you have interweb forums to ask for help. It was trial by error when I got started.
BTW, I had 4 years of engine wrenching under my belt by the time this snapshot was taken.
So now the question becomes, after I have it glass beaded (blasted is my term), what paint do I want to use and are there any paint preparation steps I need to make? Or is just it just ok after the blasting to immediately apply a spray on paint such as this Duplicolor Engine Enamel with Ceramic™, Chevrolet Orange, 12 oz. Aerosol?
Most intake manifolds I've looked at don't look like mine where the qjet sits. I'd imagine there must be an adapter. I've also been told that my qjet might sit higher and have hood clearance issues with some.
Can you give me an exact EP # I can lookup?
Iron paint prep is fairly simple - it will come out of bead blast dirty so step one is to wash it with a dilute laundy detergent, giving it a good scrub, the air dry and spray right away with a good primer - DupliColor is good stuff and I've used it; just apply the primer first. Be sure to mask off the head side of the manifold. It's also a good idea to put a light spray of WD-40 in the plenum and up the runners to avoid any surface corrosion.
"While you're in there" it's worth getting the thermostat housing blasted and painted - or replaced - and replace or refurbish any plugs or fittings. Do it once, do it right
Yes I planned on redoing the thermostat housing as well. I've also looked at getting a new choke coil and housing.
So I've been looking at some other threads about people dumping their stock intake for an aftermarket aluminum version. It looks to me like most would require converting my choke to electric, I'm open to doing that. Other threads I've read people have replaced their intake for more HP only to be disappointed that the 5-10 HP gain is unnoticable. So the main and only reason to replace it is weight savings?
I'd like all suggestions for a replacement intake.
Also, one other fellow in another thread said to NOT use the rubber front and rear gaskets and just use (RTV or Permatex #2?) a silicone sealant. Is that really the best thing to do?
The weight savings thing is a rationalization IMHO - true that less weight with the same power the car will be "faster"...but it's not a good reason to make the swap on it's own.
If you want to do a swap the Performer is a good pick and I believe will fit under the stock hood with a drop-base cleaner. You will need to move to an integrated choke - if your carb is out for overhaul you better make that phone call right now to see if it can be done. I have not seen great quality on the Summit-branded stuff - I had a buddy buy a set of heads that were complete junk, and I have seen one of these Summit intakes that were a bad casting...but still got machined and sold.
Correct - the front/rear valley gaskets are *never* used on a GEN I SBC, period. No Permatex, but a bead of RTV.
I've also been looking at the, I believe, L82 aluminum intakes casting #14057053 from the later years vettes. With all of these decisions and options, makes me want to just stay stock for now.
I have grand visions years down the road of having the 350 engine rebuilt into a 383 with fuel injection and a 5 or 6 speed manual transmission.
And yes some may think it's silly to just pull the intake to redo it and do nothing with the rest of the engine. However I don't really ever see much else of the engine when I open the hood. I just always see that nasty looking manifold, so that was reason for pulling it. I figured a glass beaded manifold would hold the new paint better than just some brushing the old stuff off would do.
I wouldn't invest in the L82 manifold myself; it's essentially an aluminum copy of the same iron intake you have - so no power to be made, although it is lighter.
Doing a little detailing work under the hood always pays off. We all like a little acknowledgement when we lift the hood
I'm not a big fan of "bling" - but doing some basic clean-up is always nice and worth the effort...and if done very well as you're doing it means that it will last and fit in well as you do other work on the engine and engine compartment.
Another more noob question that really shows I've never been inside an engine. That center valley under the manifold, that isn't filled with water is it? It's just an open space for oil to drip down? That the only place water is seen is inside the intake near the front left and right sides until it goes out the thermostat housing?
I think for now there really isn't a benefit other than some 35lbs weight savings that the 2101 will give me over the stock intake.
I've seen some recent post talking about filling that area with aluminum foil or plaster of some sort.
