Electric Fuel Pump Cut off Switch
Old May 4, 2002 | 05:55 AM
8T1-7T9 BIONIC VETTE's Avatar
Default Electric Fuel Pump Cut off Switch
Purchased a Electric Fuel Pump Cut off Switch today....Ford inertia switch....Cuts power to the pump upon impact....It has three terminals....I'm going to hook up tomorrow.....I will use multi-meter to check open and close contact terminals....however why would they have three terminals? Ford says Red pop up faces up....Hope I get this installed correctly....Works great when you tap it against a wall, the red thingy pops up and opens the circuit....press it back down and the circuit is closed....Thanks to you guys on the forum.....I sure did not want to install the oil pressure switch....since some engines will keep on running after impact. :seeya Cappy
Old May 4, 2002 | 07:10 AM
rambler323's Avatar
rambler323
Default Re: Electric Fuel Pump Cut off Switch (8T1-7T9 BIONIC VETTE)
positve negative ground??? maybe??? i really have no idea but shouldn't there be some instructions with that thing anyway? :confused:
