C6 Z06 brakes on my C3
I want to see a picture of the car with the snowflakes on it. Please.
C6 Z06 brakes
I am not planning on tracking this car. I had the parts and just decided it would make a nice street setup. The 17" wheels made the stock rotor look kinda dinky when viewed through the wheel spokes. The brake setup should perform as well or better than the original for a street driven car. Thanks
C6 Z06 brakes on C3
Wouldn't it be easier to put a C3 body on a C6 chassis?? Once you get the brake hardware installed, then you'll want to install the ABS on it. And, when that's done, you need a modern powertrain to drive it, then....then........
Love the work on the brake install; very well thought out.
Very nice set up. That would make me spring for a set of big wheels for mine too. Make sure when you make some brackets to get me in the loop too. Nice work.
C6 Z06 brakes on C3
I know what you mean. I looked at those calipers and rotors and just had to figure out a way to make them work on my C3. Now I want another set for my C-5. Thanks
I was interested in the balance. Have you got up to high speed and stomped on the brake to see if it has one or two wheels locking up?
#35
If You don't mind what machining was needed on the Front Spindles to use the 14" C6 Rotors ? Bearing mounting surface ? Or a clearance issue. You say that additional Photos were posted but I'm not finding them. Thanx,,,
#36
C6 Z06 brakes on C3
To mount the C6 Z06 front rotor on a C3 front hub you must: Machine the hub diameter down about 1/4" (approx), you must also machine the hub where the rotor centers on the hub, cut the hub down a about .010" (approx). In other words the rotor center hole is just barely smaller than the hub, and the rear of the rotor is just a little smaller than the total od of the hub. If you have a hub and a rotor in front of you, it is very obvious what needs to be done if you measure both with a caliper. It was fairly easy to modify the hub to fit the rotor. I had a machine shop do it in a cnc machine, it took him about 1 minute. He also trued the front surface of the hub to give me zero runout on the rotors. Someone with a good brake disc machine could cut the hub down to fit inside the back of the rotor. We did this once by using a longer cutter on the machine. The spindle was not modified. Thanks
#37
C6 Z06 brakes on a c3
To see the photos, search for my post "C6 Z06 brakes on 1980 C3". Thanks
#38
#39
C6 Z06 brakes on C3
If you have a lathe and a mill you should be able to do all the mods to make everything fit. The front hubs and the rear axle shafts always have runout from the factory, which multiplies to the rotor after it is fitted. If you can fix the runout on those parts with your mill or lathe you will be in good shape. Thanks
