Question about checking pushrod length
With a flat tappet cam, I'd search all the car forums I could find for either a good used set of comp pro magnum full roller rocker arms, their roller tip rockers, or Crane gold roller rocker arms. Stay away from any other brand if you go roller tip, but many companies make good full roller rockers- find some you like and post up to see if anyone has had trouble with them. I'd avoid CAT and the Chinese ones on ePay.
If the timing set was a good name brand, it will be fine. Cloyes stock replacement timing chains will outlive most performance builds, to tell you the truth. Beehives are great so long as you get the right ones for your cam.
EDIT: The springs in that kit don't look like beehives, but that doesn't mean they won't be fine. It's not a radical cam.
I looked up the valvespring part number on Comp Cams website, and it's a beehive spring, the picture isn't of the literal k-kit in question, just a stock photo of one.
Scott
Scott
Scott
Myself for a mild street engine i would go with a stamped roller tip like crane or some other name brand (Elgin?). I don't know who or ProForm parts are made but they sell inexpensive (cheap) roller tip rockers too.
But u didn't post your cam lift or rpm range so its good luck to u then.
Good night Scotty,
cardo0
Measure one cylinder, easy to do on the car with the right tools, and order one set of custom. They come in increments, but custom pushrods are available...but generally not used. Often the stock ones work fine...but we still check.
I generally don't check valve-to-piston clearance until the lift gets up around .480 or so. You'll definitely need to check ALL the other clearances - rocker-to-stud, etc.
Finally, I'm not a big fan of full rollers on the street. They're not really a daily-driver item - they're a race-only item. People do run them, but it's a waste of money.
I take your knowledge as gospel. What would you run on a street hydraulic roller in the 0.540-0.550" lift range? I'm squeamish about full rollers on the street but so many of the alternatives look like they are also fraught with risk.
I've stuck with old Pro-Magnum rollers because I had no confidence in stamped stock rockers when 300# over the nose/ 450 lbs through the pushrod forces were being applied even at 5500 RPM when they have been known to split open on some stock applications.
Your thoughts?
I position the valve at 1/2 lift. There are probably dozens of ways to do this, but I do it with a valvespring height mic set to installed height less 1/2 full lift travel. Either way, I put the valve in this position, install the rocker arm and hold the roller against the valve stem tip and hold it up against a poly lock installed on the stud. I then adjust the lock until the roller is centered on the valve stem tip. Lock the poly lock into place.
Next I remove the valve stem locks, retainer, reinstall the valve spring, retainer and lock. Make sure the lifter is on the cam's base circle by rotating the engine by hand. When I'm working on the intake valve, I rotate the engine until the exhaust lifter is just starting to open. If you're working on the exhaust valve, rotate until the intake lifter has fully opened and is almost closed.
With the valve spring installed the valve is sure to be fully closed, and the lifter is on the base circle, so I slip in the adjustable length pushrod and find the minimum overall length. I round up to the next readily available length increment and record the value. Next, I do the same thing on the adjacent valve (exhaust if I just did the intake, or the intake if I just did the exhaust).
In my case, the block has almost always been zero decked, so block height is very uniform. With new (aftermarket) heads, the valves are usually in almost exactly the same position, but it's smart to check at least the four corners of the engine (eight valves, I&E on cylinders 1, 2, 7, 8). There isn't usually much variation- within .020" or so, well within what a street hydraulic lifter can handle. I take an average of these and round up to the next readily commercially available .050" increment, then place my order.
This might not be the best or perfect method, but right or wrong that's how I do it until someone "sets me straight". Who knows, maybe it's all wrong- if so, please educate me!
