Can I drive on new cam BEFORE break-in?
Big difference between OEM-style cams and springs, even factory high performance ones, and modern aftermarket cams and springs. I can't think of a single cam vendor that doesn't recommend a similar 30 minute break-in process. As an example:
http://www.compcams.com/Base/pdf/Fla...chBulletin.pdf
http://www.cranecams.com/uploads/breakin/548e.pdf
http://www.edelbrock.com/automotive_.../2000/2102.pdf
I follow this process, adding in pre-oiling as a free security blanket, and I've never lost a cam. Folks should be really careful taking "expert" advice that directly counters what the manufacturers specify...
Think about this, Do you really think that GM ran every single flat cam engine for 30 minutes before driving the car out of the assy area? Or for every other flat cam engine in any other production area breaking these in? I highly dought it. On every engine build we do, we first prime the engine with quality engine oil. Set intitial timing, usually within +- 2* of within specs. Prime with coolant, and start it. Sure we vary the throttle some, double check for leaks, set timing accordingly. Once satified all is good, we install in the unit. We do not run at a constant rpm for any particular time at all. How many engines per year do we replace? on average 7 to 10 Not a huge amount, but with 0 failures for the past 25 years, I think we must be doing something correct. Maybe not? Al
The lobes aren't getting polished to the lifters correctly.
you dont have to go that far .but there are places that you can drive the car at that rpm.that was the question.
Which brings up another issue: If someone decides to change the cam in their engine this winter and the garage is 40 degrees, how smart is it to start the engine and rev the motor to 3,000 RPM immediately for 30 minutes? As someone all ready suggested, could that procedure contribute to cam failure?
Lastly, I personally do not think that a mild to moderate cam profile requires such a procedure. I am not an expert but I doubt when I do my cam that I would follow this procedure exactly since there is potential for other problems following this requirement.
Has anyone heated the engine oil BEFORE putting it in the engine to reduce the viscosity and besides ALSWAGG who does not follow this procedure recently and had no issues? Just curious!
You need enough rpm for two things to happen:
1) The lifter needs to rotate. If the lifter "gets stuck" (doesn't rotate) in the bore the lobe will wipe.
2) the only oiling cam lobes get is splash oil from the crank. There's not enough splash oil at idle for break-in.
I don't think 3000 rpm is needed. Long time ago when I ran FT cams I broke them in at 2000 rpm.
Are you saying I have just been lucky???? No cam failures, no crank brg failures, no toasted engines. Now, I would have to say, we have not built and installed an old style flat tappet cammed engine for a very long time. If a pre Vortec engine comes in to be replaced, we build a Nice small block utilizing a ZZ4 rotating assy. As all know with this configuration roller lifters are used. Again, no special cam breakin. Again bullet proof engines. I guess I look at how manufacturing would build and prep. I just do not see GM running every motor for a special cam break in of 30 minutes at a constant rpm. The time restraints would dictate this alone. Al
http://forums.corvetteforum.com/c3-g...in-1970-a.html
This has already been discussed, but it is a great topic. I did not know GM ran the engines on Natural gas or propain on the assy line, Good idea due to lower emissions. Al
Received 3,043 Likes
St. Jude Donor '05
Didnt hear that either but how to verify so it doesnt become a net rumor?
St. Jude Donor '09
Set the idle to no less than 1500 and go do what you want with it....no need to sit in one place
#33
For us home garage guy start the motor, immediately set the timing as close as you can get. Use the idle screw and change the rpms every few minutes from 2 - 3000 RPM's
