removed smog pump on my 1981
#41
Ok, some are going to get angry with this, but DO IT THE RIGHT WAY! Don't crimp with vise grips! Dont bend it over, etc. THis is YOUR Corvette! DO it the right way!
Either:
1. Drill them out, tap the holes and insert brass plugs. (I did it this way before real headers)
2. Drill them out and tack weld the holes shut.
Crimping them over looks really bad, and will sound like "psss, psss, psss," when you run it if they are not totally sealed.
eBay also has used stock manifolds that already have the work done. Heck, PM me, and if I can find my old ones, pay for shipping and they are yours!
Ok, my .02 ..
Either:
Ok, my .02 ..
#42
To Mike Ward: BECAUSE...They look like CRAP, and it is thier car, you always have a condescending tone about your posts when someone does something you don't like......get over it, its not your car!
#45
Cruising
pipe plugs
I just Tig Welded mine. The pump and all electronics were gone when I bought My 81. I have a small cam and edelbrock performer manifold and a Qjet. Runs great and much quicker then stock 81 and still get 17 mpg.
#46
I removed the smog pump, computer, and all other smog components. I installed an air gap manifold, edelbrock carb and headers. I set up the timing and the car runs SO MUCH BETTER. I do still need to re-curve the distributor, but it's like a different car altogether. I do feel that it was well worth the changes, not f/ looks, but f/ the performance and simplification of the under-hood maint. and over-all work.
Don't fool w/ the factory headers, purchase a set of long tube headers and be done w/ it.
#47
EGR and AIR will not hurt HP, but removing them certainly simplifies the engine bay. Calibrating the carburetor and distributor are much more important than axing these components.
#48
"After you remove the pipes, and before you put theplugs in you have to remove the short tubes that are sitting inside the holes. They are about 3" long and just sit in the holes. You can get them out by threading a self tapping bolt into them and pull them out. I've never seen it happen, but apparently without air running through them they will get very hot and droop into the exhaust manifold.
Steve g "
Steve, that is correct for the older cast iron headers. The 81 has SS tubular headers and the AIR tubes are brazed into the tubes and only extend about 3/8" into the header tube.
The best soulution is to buy a set of take off 81 headers which you can find cheap on EBay, cut off the tubes and drill out the stubs then take to a weld shop and have them TIG the holes closed then swap the headers. The easy y out is what I did is what a previous post suggested is to put a brass pipe plug in the top of the collector where the AIR fitting screwed in. Don't look great but it works.
Steve g "
#50
i am going threw the same kinda issue on my 81, a PO decided to remove the AIR pum and EGR seliod, and some strange reason the cruise servo ( i think he did not what he was takin off) so now i am stuck with a "BUBBA'd" mess, at first i was going to replace the pump and selinoid, but dont have the extra cash this year, it gets cold fast here lol. so i decided to leave AIR pipes on the factory shorty's but i really want to clean up the vacuum mess i get stuck with, and i am at a loss on how to re route or what to plug, or just simply remove. i removed the wire hurness for the AIR pump and when i removed the groun from the thermostat housing suprising enough the ECM decided to stop the car from starting (nice lil basic computer (shaking fist at it in the air)), after i figured out to reconect that ground, it came back to life. there is another ground that looked like it went to the back of the block just off the valve cover that is still unhooked, i am think of re grounding this to see if it helps my idle at low speeds ( it sputters a bit when getting up to 30 mph, but not sure it will do more harm, if anyone has any suggestions of how to clean up this mess or the other broken ground it would be great. thanks so much i can send pics to anyone can help, but i cant seem to post them in the post
#52
Hi All,
I'm not trying to bring a thread back for the dead but I'm a little confused by some of the things mentioned here. I pulled my air pump yesterday because it was in the way on what I was working on. I decided not to put it back on. In doing so I capped off the two smog tubes but left them connected to the exhaust manifolds. This was a quick an easy job but I will probably pull them off completely later on. I understand they are screwed in with what looks like a brake line fitting and behind them are the 3" tubes that are pressed in which also need to come out. My question is why are people having to go the great lengths to seal these holes up once the smog tubes and 3" tubes are removed? Couldn't you just screw in the correct size plug into the 8 holes on the exhaust manifold? Or is this only an issue with 81 and up headers? Mine is a 80 and I have cast iron manifolds.
Thanks,
Sam
Thanks,
Sam
#53
Hi All,
I'm not trying to bring a thread back for the dead but I'm a little confused by some of the things mentioned here. I pulled my air pump yesterday because it was ion the way on what I was working on. I decided not to put it back on. In doing so I capped off the two smog tubes but left them connected to the exhaust manifolds. This was a quick an easy job but I will problem pull them off completely later on. I understand they are screwed in with what looks like a brake line fitting and behind them are the 3" tubes that are pressed in which also need to come out. My question is why are people having to go the great lengths to seal these holes up once the smog tubes and 3" tubes are removed? Couldn't you just screw in the correct size plug into the 8 holes on the exhaust manifold? Or is this only an issue with 81 and up headers? Mine is a 80 and I have cast iron manifolds.
Thanks,
Sam
Thanks,
Sam
The Recessed Allen socket head ones will have the cleanest look.
They are pipe thread
#54
That's what I thought, thanks. I was getting a little confused with people saying that had to either crimp the end, tap the holes or weld them shut.
#56
when i had mine capped, I just left to one way valve on pipe and put a rubber cap over it. if the valve is working properly there is no problems.
also, '81s and '82s had stainless manifolds, so the tubes are welded into the manifold, not threaded in like a cast iron manifold.
and the engine looks so much cleaner and is much easier to work on, a plus for people like me who are always tinkering.
#57
Smog pump
