wiper door-'72
When you do the transmission adjustment you put the arm and blade under the stop and tighten. When finished, you pull the arm over the stop and let it rest on the stop. It will feel tight on the stop but it should be correct. Then adjust the tilt of the blade with Screw A.
Received 2,878 Likes
Hi l,
2 things I notice:
There's a bend in the arm that you see in the picture that shows the arm from the side. The arm should be parallel to the glass the whole way to the blade connection.
The vacuum switch is a replacement (white plunger is the give away). Is it possible the replacement's holes don't have as much adjustment as the originals?
Regards,
Alan
This one (you should be copying the IMG code the last one.)
2 things I notice:
Regards,
Alan
Cruising
wiper problem
Thanks Dave & Alan
The wiper procedue in in AIM is not very clear. Thanks for the tips, I will try in am tomorrow.
Alan- I looked at old switch ( I keep every old part I remove for reference or ?) Holes line up perfectly w/replacement switch. I wondered about that too. Thanks also for the photo posting info.
Hi l,
2 things I notice:
Regards,
Alan
2 things I notice:
Regards,
Alan
So far as the vacuum switch goes. I have a replacement in my 70 which provided ample adjustment. The adjustment didn't come from slots on the switch, it came from slots in the bracket. There are a few clip nuts on the bracket which can be shifted up or down.
Hi l,
YES! BB is right. Look how long the blade is compared to the holder. Is this the cause?
Regards,
Alan
Original blade, holder, arm.
Regards,
Alan
Former Vendor
Received 1,813 Likes
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Back to Screw A... :D
Been gone a few days. Yes... I've been wanting to do this for a while to today I pulled the lower cover off a wiper arm and took some pictures.
Below shows the function of the mysterious Screw A. Now let me look at the rest of this thread to see what I've missed.
Hi Ernie,
That picture is a real keeper.
I've never seen the inside of the arm... a little more complicated than I thought.
NOW I see how it adjusts the 'sweep'!
Regards,
Alan
Regards,
Alan
Former Vendor
Alan-
Most people don't even realize the screw is there.
Hi Ernie,
People complain about the AIM being so complicated.... and it is.... but there really is a lot of information in those pages! Including 'screw A'.
Regards,
Alan
Regards,
Alan
Thanks.
Former Vendor
I may start a thread on Screw A..... with the new picture it may save some grief...
Cruising
still battling
I thought recent suggestions would solve my problem but still no luck. I have noticed that problem seem to be wipers stopping then door comes down on top of pass wiper. I have adjusted, re adjusted....... linkage per AIM and previous posts but wipers still stop before door comes down. The driver wiper stops about 1/2" above bracket and pass side arm is struck by the top rib of the wiper door. I have also tried adjusting the wiper switch on firewall but no luck. Perhaps I do not understand the vacuum/electrical interface of wiper motor shutoff/ door vacuum. I have not lengthened the bolt holes of the wiper safety switch yet and I do not know if this would resolve the wiper position at shut off problem. Any ideas?
#33
It sounds to me like the vacuum system is working as it should. The wipers park and then the door closes. The purpose of the vacuum switch is to prevent the door from closing until the wipers park. The problem has to be in the wiper adjustment. Could the vacuum switch be preventing the wipers from parking all the way down ? When fully parked the passenger wiper arm only has to depress the vacuum switch 1/2 way for it to operate. Adjust the wiper arms to fully park, then adjust the switch to be depressed 1/2 way. Did you pull the wiper arm off and straighten it ? Good luck. Are these cars fun to wrk on or what ?
#34
Hi RV02,
Mostly...."or what"!
Regards,
Alan
Regards,
Alan
#35
Former Vendor
So you have two things going on right now....
For the wiper door to shut, the valve under the arm must be compressed. For the wipers to stop working the plunger that hits the limit switch must also be depressed.
I looked at your pictures... and the passenger side arm seems to be bent, did they also bend it in a lateral position?
For what you state, the plunger had to be closed to shut the door and the plunger has to be closed to shut off.. so, I'm putting my money on adjustment, a bent arm or.. bad transmissions.. you'll have to take a closer look.
Did you ever get the arms to adjust out per the instruction sheet? If not then I'm sure something is bent and this could include the transmission levers from the motor bell crank to the arm shaft.
Food for thought for sure...
Willcox Inc.
#36
Just a quick note to add to the discussion...I have noticed that it is very hard to find "wiper inserts" anymore in the normal stores. I have also noticed that many of the new wiper blades sold have a higher profile that the originals, which could lead to some door interference if the wiper blade/frame profile is too high. Any thoughts?
#37
Azza
#38
I recently replaced the wiper safety switch. Wipers function well but when turned off the door closes on top of the passenger wiper arm where it bends down toward glass. The transmission link cannot be adjusted further and the switch is as far down as it can go on the bracket. What could cause the door to close prematurely?
You need to adjust the linkage on the arms that push/pull the arms.
One arm closes a hair quicker than the other .
Read the willcox adjustment procedure.
I had THE SAME issue. If the arms are correct, you can adjust this to work.
