Opinions on a 502 with electric fuel pump
Supporting Lifetime Member
I have an opportunity to pick up a ZZ502 at a great price. Engine should be great in my '69 so no worries about that. Only issue is that it doesn't have the mechanical fuel pump boss, so I'd have no choice but to use an electric fuel pump.
Anyone see any issues or have any opinions? Good, bad....
Thanks!
Thanks!
St. Jude Donor '11, '14
Every car on the street since the mid 80's is using an electric fuel pump. You should have no problems. Install a good filter at the same time.
Rob
Rob
Thanks!
Thanks!
The engine is great. All the power you need and it's relatively mild and very streetable. If I ever have to rebuild it I would swap in a 1/4" stroker crank to make it 540 CID and a slightly bigger cam since it seems to run out of steam around 5500 rpm.
BTW, I'm using the '69 small block radiator and it never goes above 190*.
One more thing to note, you will need to get an adapter for the clutch stud boss if you have a manual transmission.
Scoggin-Dickey makes one specific to the corvette.
I knew I needed to check for the boss, but if it's there, can't the hole be drilled and tapped for the clutch stud?
P/n is SDCBV
I use Mallory 140 electric's on everything. Nice being able to fill the carb bowls before hitting the starter, and running things out on shut down with a dash switch. Go for it, as you'll like the set up a lot.
Not sure what you were planning to use but this kit from Weldon is a great value and their customer service is just fantastic.
I have their kit in my car.
http://www.weldonracing.com/product/...Combo_Kit.html
Received 1,874 Likes
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
I've used the Aeromotive A1000 pump for years on my 555. Works great...reliable on cross country highway trips.
JIM
PS- I vote for a cam change too. ZZ502's run out of steam way too early due to the mega weenie cam. Everything else is good on them.
JIM
