Timing Advance
Old Feb 28, 2012 | 09:16 AM
newbie2vette's Avatar
newbie2vette
Default Timing Advance
How far can a small block be advanced before it is harmful to the engine? I am experimenting with water injection, I have the timing at 116 BTC.
Old Feb 28, 2012 | 09:23 AM
billla's Avatar
billla
St. Jude Donor '14
Old Feb 28, 2012 | 09:28 AM
Peterbuilt's Avatar
Peterbuilt
116! Did you mean 16?
Old Feb 28, 2012 | 09:29 AM
pws69's Avatar
pws69
Old Feb 28, 2012 | 09:30 AM
69 Chevy's Avatar
69 Chevy
116? No way, dude.
Old Feb 28, 2012 | 09:41 AM
newbie2vette
[QUOTE=petes74ttop;1580134807]116! Did you mean 16?[/QUOTE
Yes, Fat fingers.
Old Feb 28, 2012 | 09:46 AM
billla's Avatar
billla
St. Jude Donor '14
Without being on a dyno, I can't see how you can determine if anything you're doing is making more power. The general advance curve for a GEN I SBC is pretty well-documented, and more advance doesn't automatically mean more power.
Old Feb 28, 2012 | 09:52 AM
Peterbuilt's Avatar
Peterbuilt
Did you read this?
http://forums.corvetteforum.com/c3-t...long-post.html
Old Feb 28, 2012 | 11:51 AM
zwede's Avatar
zwede
Disconnect vacuum advance, rev to 3000 and check advance. Any more than 36 will not make any more power on a GEN 1 small block.
Old Feb 28, 2012 | 12:07 PM
Mike Ward's Avatar
Mike Ward
Initial timing at idle means nothing especially when the advance curve is not specified. The factory settings are simply a reverse engineered reference number that make it easy to set timing during 'tune ups'.
Old Feb 28, 2012 | 04:40 PM
7T1vette's Avatar
7T1vette
The factory setting also 'detunes' the engine for lower power [hence, lower warranty costs for GM] and for lower emissions.
To Timing Advance
