Head Gasket Copper Spray
Its another 'Permatex gasket product in a spray can similar to Copper coat except its a red sticky spray on composition.....several 'red branches on trees in Holiday Inn`s parking lots through out the South from spraying copper head gaskets.....
This is what I was recommended to use for my engine build and I have aluminium heads.
http://www.permatex.com/products/Aut...ve_Sealant.htm
Just rang Permatex Tech. line and was told that the amount of copper in this produst is minimal and there is no issue with this product and Aluminium heads.
87-PERMATEX (877.376.2839)
Go ahead and use it
Go ahead and use it
I used the Permitex copper spray on my head gaskets, the gaskets were .015 steel shims and manufacture recommended using a sealer. Have not had any problems so far.
