fighting the brakes
Old Mar 16, 2012 | 06:07 PM
pleasants9's Avatar
pleasants9
Default fighting the brakes
my front brakes don't seem to be agreeing. When I hit the brakes the car pulls to the right, as I press the brake more it seems to pull more. I don't seem to be leaking any fluid...is it my calipers or is there a brake proportioning valve? any ideas, things to check?
Old Mar 16, 2012 | 06:13 PM
7t9l82's Avatar
7t9l82
I'm thinking a hose. kok
Old Mar 16, 2012 | 07:35 PM
pleasants9's Avatar
pleasants9
think a hose is leaking or has a kink in it??
Old Mar 16, 2012 | 07:38 PM
Marlin's Avatar
Marlin
I would remove the front wheels and look for damaged hoses and leaks from the calipers.
Also make sure you are not metal to metal on the pads.
After that I would rebulld the calipers (O-ring IMO) and do a good flush and new pads.
Old Mar 16, 2012 | 08:26 PM
BadAssRocker's Avatar
BadAssRocker
Does it pull only when you hit the brakes or all the time?
Old Mar 16, 2012 | 09:19 PM
gcusmano74's Avatar
gcusmano74
Very often, a right/left pull under brake application can be caused by worn suspension components, not brakes. Having said that, years ago, I had a front brake hose fail internally. It looked fine from the outside, but a piece came loose inside and it was partially plugged.
Old Mar 16, 2012 | 09:33 PM
Shark Racer's Avatar
Shark Racer
Yep... amazing what weight shift will unlock in a suspension... funky toe changes when parts are worn.
It's always ended up being a leaky caliper for me though.
Old Mar 16, 2012 | 09:45 PM
bobs77vet's Avatar
bobs77vet
From: Arlington Va Current ride 04 vert, previous vettes: 69 vert, 77 resto mod
very often the rotors are out of true after being mounted and perhaps on the left side it is making the lip seals in the caliper suck in air......so when you brake the air is compressing on the left and the brakes are applying on the right.....try bleeding only the left side caliper and see what happens.
To fighting the brakes
