Anyone had a Holley nightmare like this?
I`m lazy and if a needle and seat is the problem which I suspect that it is, I blow air into the fuel inlet in any convenient place to separate the line between the pump and carb/carbs. The carb with the problem will have the seat open and blow the obstruction out......works with all manifolds 1. 2, 3, 4, or whatever......
like my little 289......
427 Hotrod...thanks a buch. I took your shortcut and pinched the fuel line going into the pump. Started it up and feathered like crazy. Removed the pinch and started her up.
Smooth as silk, Rog wicked happy. Checked all my float bowl levels. They were all still perfect.
Gotta love this forum!!! THANKS
Sounds like a float got stuck just pull the bowls off and reset them. I know its pain with the tripower but its got to be done.
Yeah because to you its a major "radical" event to remove some carbs.
At least it was an actual suggestion and not just someone posting pics of carbs off someone elses website who obviously has never worked on them.Your the typical forum know-it-all who actually knows nothing.Im glad the guy didnt have to take them apart but if he did no big deal he would have seen how much crap is in the bowls which may in fact still be there I do things right the first time and not take shortcuts.Stop posting negative comments about peoples suggestions just because you dont agree with them.
Correct me if I'm off base here...aren't 2300 Holley carb float bowls similar in design, function and repair than those used in models 4150/4160?
So, are you saying that Trip 69 actually took a cheap shortcut route and his fix is only temporary because he did not follow your
...just pull the bowls off and reset them. I know its pain with the tripower but it's got to be done?
You did make an actual suggestion. To me, it should only be taken as a last resort...way to involved with all the fuel feed piping and the throttle linkages. Not to mention the likelyhood of having to replace all 3 carb to manifold gaskets.
Lets just agree to disagree and end the thread.
