Backing in to decent heads for a cam...
Keep the shiny side up!
Scott
That's 40 HP and ~55 tq over what mine is rated currently, assuming my cam still works as well as the one GM picked.
I'm nearly sold.
JEGS typically has the best price for some reason, then it's just the rockers, gaskets, valve covers, head bolts and intake.
The rockers are P/N 12495490 for around $65.
GMPP head bolts are dirt cheap under P/N 12495499 for about $35.
Take-off valve covers I typically get for ~$20 from the Online Auction Site (you know the one )
Intake gasket is the Fel-Pro 1094...but be sure to measure deck height beforehand.
And of course, check valvetrain geometry and clearances afterwards.
I'm not entirely sure what GMPP does to its blocks used for the crate engines it sells as "remanufactured". If I were being an optimist, I would hope that meant that it was not decked and fit the "brand new" dimensions, but I really don't know.
Interesting. I'll be somewhere between 9:1 and 9.5:1 with 64cc heads, if I got the particulars right on the calculator that I found, so detonation shouldn't be too much of an issue, unless there is something else that I'm not considering.
I have yet to see back-to-back testing validating this perspective. Tests by Car Craft and others failed to support this perspective, while admittedly also not disproving it either. Regardless, I don't personally plan a build based on this perspective. Even if this were the case, 1/2 point of compression is worth...1-2% power on a build making < 1.4 HP/CID?
The observation that a larger cam would be required to use Vortec heads on this because they're iron just isn't applicable here - which was the basis of my comments.
Is this because the piston may be "out of the hole" too much for the thin gasket, or is this for some other reason (pushrod length, etc.)?
GMPP block aren't machined square - the deck won't be square to the crank centerline and the deck heights can be anything, and can be inconsistet cylinder-to-cylinder. Not a big of a deal on a moderate build, as much as some will make of it.
Deck height on any engine is a complete unknown until measured. It's typically around .020-.025...but I've seen less and more. One guy on the Forum found .040 deck height on a stock engine...so there's just no telling
Labelled "deck clearance" here?
The spec we're chasing here is quench - the distance between the top of the piston and the bottom of the head. The "ideal" quench is around .040...so we try to find a workable combination of deck height and gasket thickness to achieve that quench.
Once we know the deck height, we can see how well we can do to get around .040. The 1094 gasket is often a good choice as the stock deck is often .025 and the compressed thickness of the gasket is .015...so .025 + .015 = .040...perfection
#33
Apologies - let me back up for a moment.
#34
Yeah, most people say deck height when they mean deck clearance. It is such a commonly used term that even people who know better say it. Don't get wrapped around the axle about it. If it's several inches, it's the actual deck height. If it's a few thousandths of an inch, it's the deck clearance. If you try to point out the difference you will just end up involved in pointless arguments.
Scott
Scott
#35
Scott
Scott
Thanks again all.
#36
Location: Las Vegas - Just stop perpetuating myths please.
The best bolt on for u to go faster is a blower.
Yes a supercharger. It matches your heads, cam, and compression ratio. Just retard the timing. OK, i know those cast pistons won't last at high rpm and hp. But use a rev-limiter with the smaller 141c.i. blower for mostly street driving and you should be fine making somewhere in the 400hp - 450hp range. U may find u need a good transmission to handle the greater torque. In fact your trans could be slipping now so bad thinking the engine is too doggy (i upgraded my 4L60E to a BTO level 3 and wow now). IMHO bolting on a supercharger is much more fun than swapping heads and scrapping head gaskets - what till u try and get the stock composite gasket off. Blowers look expensive but once u start shopping for used 141 c.i. blowers the cost drops fast.
Yes I can't see how u can overlook the GMPP catalog for head swap comparisions - that's what i would suggest for a head swap comparo of GM crates (HO). Your current cam has more duration and wider LSA moving u higher in the rpm range for max power but idle vacuum may even be improved. So just bolting on some Votecs should see good power improvements.
But i recall u just got this motor installed and running. Don't u want to play with it a while? A low compression motor like that is very hard to break. My suggestion is maximize your tune with an O2 sensor - they're cheap and invaluable for modern tuning. Get the carb dialed in first - mid 12:1 mix at WOT and 15 something at cruise. Fuel pressure and pump shot can be concealed issues reducing power and response.
Also optimize your timing curve. Learn how to get full advance 32* at least or more in by 3000 rpm. Match up your weights and modify post bushings to get idle advance below 10*. Map the timing advance from idle to 3000 rpm and play with it to see whats best for your car.
Another bolt on is 1.6 rockers and on a mild 350" like yours i would install them on intakes only. Do you have and H pipe crossover exh - few more ponies here?
These are all very inexpensive improvements (without the blower) that take time and patience rather than much cash. But they provided very helpful experience once u step up to high dollar parts.
Good luck nate,
cardo0
They basically do with the 350 HO (330 hp/380 tq) engine, and I would have been better off starting there, though the cam they use on it is just a hair smaller. .435/460, 212/222 112.5 LSA. 9.1:1 compression, which is probably close to where I would be with 64cc heads.
I'm nearly sold.
I'm nearly sold.
Good luck nate,
cardo0
#37
Good luck nate,
cardo0
Good luck nate,
cardo0
I have thought about a small blower, but am really hesitant to cut a hole in the (or get a ridiculously high) hood. If I run across an elegant solution there, I could see myself getting talked in to it. There was a guy that had dual Weber carbs on some kind of trick B&M intake that looked really cool.
But me and dual Webers on a s/c engine would be about a dozen bridges too far.
