TPI swap with a modern twist
Old 04-13-2012, 12:09 PM
mrvette
mrvette's Avatar
Back in '95 I paid 350 bux for a complete TPI at a Carlisle car show, did the junkyard routine for computer and wiring harness connectors, did my own harness, tuning chip was 150 bux or so....with new fuel pump and filter, it was on the car and running for like 750 bux total....
changed induction several times, it's now a LT1 intake on the L98 engine, and same essential wiring....
Old 04-13-2012, 01:35 PM
6inarow
6inarow's Avatar
Originally Posted by moonsteel
Sure. I'll leave shipping and taxes out (I live in Canada).
TPI used $250 (I've seen them as much as 400-500)
Holley HP EFI $1500
Tanks Inc PA-4 fuel pump $250
How detailed a breakdown do you want of all the kibbles and bits?
That is perfect. Thanks!
Old 04-16-2012, 11:19 AM
moonsteel
Holley HP EFI w/TPI
Support Corvetteforum!
moonsteel's Avatar
Assembled some AN fuel lines this weekend.
http://forums.corvetteforum.com/c3-t...-assembly.html
Old 04-26-2012, 09:24 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Fuel mods done.
Plug and weld to close front feed line
Tap FPR for AN6 fitting
Drill and tap cold start feed for AN fitting (this will be feed)
Old 04-26-2012, 09:42 PM
MikeKey
MikeKey's Avatar
I've always liked TPI as I had two 3rd Gen's with it. If you're going for drivability only, what kind of MPG and HP are you expecting? Or are you staying within in stock limits?
PO set my car up to be quite the little off the line rocket, which I enjoy, but it sucks on a cruise, especially with the 3 speed. And LS1 swaps are way more than I want to do at this stage in my life, but TPI with a 700R4 is appealing.
Old 04-27-2012, 01:21 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
I don't expect much of a change in HP, I haven't touched the engine.
Mileage, I'd like to see 20mpg, I'll know more once it's tuned.
Drive-ability is one of the main factors for choosing EFI.
Old 04-30-2012, 01:08 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Intake installed, with fuel rail
Old 04-30-2012, 01:10 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Wiring harness, planning to go through the firewall here
Old 04-30-2012, 04:55 PM
brando1118
brando1118's Avatar
That's where I went through with my FI harness.
Old 04-30-2012, 05:29 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Where did you mount the ECU?
Old 04-30-2012, 06:18 PM
brando1118
brando1118's Avatar
Hi Moonsteel,
I mounted it behind the glove pocket lower dash panel.
I winds around my Classic Auto Air panel and heater-A/C box. Here's some pics
Panel off viewing from the firewall looking towards the back of the car. The harness is insulated from the heater hose line.
Panel on:
Interior passenger side looking towards the front of the car. This is where the connector to the ecu comes out.
Couple of different angles:
Old 05-01-2012, 01:20 PM
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
How is the mass-flo attached, I don't see screws along the top.
Old 05-01-2012, 01:53 PM
  #33
brando1118
brando1118's Avatar
Just self-tapping screws. It's still not attached b/c I'm right in the middle of the project. But I have had it mounted when making preparations for the final placement.
Old 05-07-2012, 01:31 PM
  #34
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Small update, fuel lines installed and the fuel tank is back in the car.
Two of the AN fittings were not machined correctly, so I can't finish installing the lines
I did install the injectors (ordered new ones) and put the tubes on.
Took the exhaust down to Midas and got the bung welded in
Old 05-09-2012, 12:58 PM
  #35
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Now that the fuel tank is back in, I'm focusing on the engine bay, lots of wires/hoses/sensors etc.
Progress so far:
Old 05-09-2012, 12:59 PM
  #36
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
The Holley kit has been super easy to install, everything is clearly marked
Old 05-09-2012, 05:10 PM
  #37
MikeKey
MikeKey's Avatar
Looking real good. Is she running now?
To TPI swap with a modern twist
Old 05-10-2012, 03:19 PM
  #38
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
Nope, still waiting waiting for the parts from Summit
Old 05-11-2012, 07:51 AM
  #39
MikeKey
MikeKey's Avatar
Been since 2003 since I had my IROC and fiddled with TPI. But I do recall speed density in 91-92. Did the HP ECU take care of that for you? Or are you modifying the plemun.
Old 05-11-2012, 09:53 AM
  #40
moonsteel
Holley HP EFI w/TPI
moonsteel's Avatar
HP comes with a GM MAP sensor, just plan to use one of the existing vacuum ports to get the signal.
Quick Reply: TPI swap with a modern twist
