Spring Fix-up Questions
Old May 19, 2002 | 06:36 PM
LT4play's Avatar
LT4play
Default Spring Fix-up Questions
I have two minor problems, on my 1978 Corvette that I cannot get to the bottom of.
1) The black molding that is around the rear window is beginning to come up. I cannot figure out how that is mounted on there, is it just glued or are there clips on the underside from inside?
2) My gas tank cover rattles (left-right) when the door is down, but when the door is up it is sturdy. What would cause this?
Thanks in advance for any insight you might have.
Andy.
freemyer@juno.com
