Springs or weights needed to lower mechanical advance
Not looking to jack the thread but have the exact same year and motor. Am going tomorrow to buy the recurve weights and other tune up parts. I see they come with several sets of springs, which ones do I use? If I do not move the distributor, and I know timing is right now, do I need to check timing? Dont have a light but checked at my buddies last week and he said dead on.
Has this been a issue since you've had the car? If not its probably just that the original springs are becoming fatigued and stretch way to easy. you can buy a moroso or mr. gasket advance kit, 20 minutes to install. if it's done this all along, retard the timing by to degrees at a time untill it doesn't ping.
