Exterior Door handle spring
I'll let you know if I don't have any luck with McMaster Carr. I found several options and the pricing is like $1.00 each which is cheap.
I want to keep my original handles since I'm the original owner so I only need the springs. Let me know if you want to sell only the springs for both sides with shipping to 14304. If so please pm me a price. If I can't find a good match on McMaster Carr, you'll be my back up unless the price is right on yours.
I guess I have couple options:
- Purchase the new handles from Wilcox, $19.00 each and only use the spring.
- Got stock rod from Lemans Blue and make my own
- Take up dead end cruisers offer and use those springs
- Find a good replacement on McMasterr-Carr for $1.00 and bend over the ends to grab onto the arm.
Wrong spring, (I think)
Thanks for the reply 78anniversary, I noticed that one but it doesn't seem to have the same bends at the end to hook over (interlock/grab) the arms like the one in the images I posted. Also it seem to be wound about 5 times in the OEM yet around 10 in the aftermarket as well as the aftermarket seems to have a smaller inside diameter.
I do however need the spring to stop the handle from sagging.
Wilcox,
Wilcox,
With all due respect, I think you are wrong. The spring in your opening picture is NOT the spring that holds the "flap" up, but one that keeps the external lever pushed against the "piston" that is part of the hinged external handle (or flap, as I call it).
The spring that 78 Anniversary showed you is, I believe, the CORRECT one, but it fits INSIDE the hinged outer flap and rides on the pivot pin for the flap. There is even an explanation given of how to remove that pin, and therefore spring, and this is what I think you need to do.
Just grab a hold of one of the outer door handles, depress the flap, and you will see the spring. If I'm wrong, I humbly apologise.
Regards from Down Under.
aussiejohn
MMVLF,
aussiejohn
aussiejohn
door handle sping
I see what you mean. There are 2 springs on the door handle. The one from Willcox is located inside the handle and is the one that keeps the handle from sagging. The handle needs to be disassembled for it to be changed. If the spring that is visible in your pictures is broke, i"m not sure where to find those.
JETS C3-C4 (03-20-2020)
I know this is an old thread but I just went through this. Factory handle much better than aftermarket so I went this route. Spring works perfect but has to be bent out on the tail out and inside door space trimmed for obvious reason. Got spring kit from Autozone. See pics.
67:72 (08-26-2023)
