Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Reload this Page >
How do you keep the C3 from getting light above 120mph?
Old 09-13-2013, 06:04 PM
  #201
MrJlr
CF Senior Member
MrJlr's Avatar
Liked 5 Times in 5 Posts
I think yer all nuckin' futz !
WAY too fast for me in a C3 !
MrJlr is offline
Old 01-26-2014, 11:42 PM
  #202
roscobbc
CF Senior Member
roscobbc's Avatar
Liked 13 Times in 13 Posts
With all that has been said so far on this thread it makes the 212 mph speed recorded on the Mulsanne Straight at LeMans in 1972 by no.4 L88 Corvette seem even more remarkable.
roscobbc is offline
Old 02-05-2014, 01:07 AM
  #203
FastEddy
CF Senior Member
FastEddy's Avatar
Liked 1 Time in 1 Post
Back when race car drivers had *****....instead of money
FastEddy is offline
Old 02-05-2014, 03:04 AM
  #204
bebezote
CF Senior Member
Liked 35 Times in 28 Posts
my interest in my c3 is either street drag or 40 roll to 120-;;; destroying every 911 turbo, new vette, etc... with as much nitrous as needed to do it....gas baby gas !!!
bebezote is offline
Old 02-05-2014, 05:18 AM
  #205
terrys6t8roadster
CF Senior Member
terrys6t8roadster's Avatar
Liked 178 Times in 173 Posts
Default hood mods
took 18 months, turned out functional, slightly heavy.Name:  blue car 011.jpg
Name:  blue car 020.jpg
Name:  blue car 069.jpg
Name:  blue car 070.jpg
Size:  75.3 KB next is to lower the front as it is still up 7"s. T
terrys6t8roadster is offline
Old 02-05-2014, 10:31 AM
  #206
martinsw
CF Senior Member
martinsw's Avatar
Liked 9 Times in 2 Posts
ROFL ....
martinsw is offline
Old 02-05-2014, 10:35 AM
  #207
pauldana
CF Senior Member
Support Corvetteforum!
pauldana's Avatar
Liked 278 Times in 223 Posts
terrys6t8roadste
That is some beautiful work.... I'm impressed... the scoop, the CAI setup, the radiator exhaust... all of it...
pauldana is offline
Old 02-05-2014, 02:15 PM
  #208
doorgunner
Doorgunner's '68 Project
doorgunner's Avatar
Liked 793 Times in 726 Posts
Originally Posted by TheSkunkWorks View Post
Pressures differentials from above to beneath the hood vary, and you want to make sure you don't open anything up where pressure above is greater than that directly beneath any specific location. So it depends on where you intend to vent as to whether or not it would prove beneficial. Other than for isolated CAI, I'd look elsewhere than at the cowl just ahead of the windshield. Besides, in city traffic the lack of a rear hood seal invites hot engine compartment air into the cabin.
FWIW, tho I've studied up on this stuff a bit, I don't have a sheepskin in the subject, but if I can ever afford to get my shark back in service I do have instrumentation on hand with which to gather supportive data. (Donations to the cause graciously accepted. )
I won't be doing 160 mph....but I needed to know about the under-hood rear seal...thanks!
(I realize no one wants to add weight...but my '69 Camaro came stock with a pair of 50 lb. each canisters mounted on the outboard radiator support ends....and a pair in the trunk by the tail lights)
doorgunner is offline
Old 02-06-2014, 07:53 PM
  #209
terrys6t8roadster
CF Senior Member
Originally Posted by pauldana View Post
terrys6t8roadste
thanks that is nice to hear. T
Old 02-08-2014, 08:32 AM
  #210
1427
CF Senior Member
Liked 3 Times in 3 Posts
Originally Posted by terrys6t8roadster View Post
took 18 months, turned out functional, slightly heavy.Attachment 47764580
Attachment 47764581
Attachment 47764582
Attachment 47764583 next is to lower the front as it is still up 7"s. T
I had a hand in this hood along with Terry and Jim. You don't want to know the barbell on this one!
1427 is offline
Old 02-08-2014, 08:35 AM
  #211
1427
CF Senior Member
Too early in the morning . That should be barbill
1427 is offline
Old 02-08-2014, 11:37 AM
  #212
doorgunner
doorgunner's Avatar
I guess it could be barbell.......depending on how many times/trips that the bell got "rung" at the bar.
Old 02-08-2014, 04:09 PM
  #213
1427
CF Senior Member
****, now I got to buy this *#>ckerball a bell for his garage. Christ I was just getting him used to me not throwing away the empties. (pisses him off)
1427 is offline
Old 02-09-2014, 03:30 PM
  #214
FastEddy
CF Senior Member
FastEddy's Avatar
On the triple digit subject.... I'm finally swapping out the 5th gears in my Tremec - to the proper ratio so she'll continue pulling hard past the 140's...
The car actually had a better top end charge with the ole muncie and a 3:08 rear... will be nice to remedy that
FastEddy is offline
Old 02-09-2014, 11:29 PM
  #215
pauldana
CF Senior Member
pauldana's Avatar
EXACTLY what i need to do also....i screwed up ordering the .64 od... should have done the .82.... bad mistake
pauldana is offline
Old 02-10-2014, 05:00 AM
  #216
terrys6t8roadster
CF Senior Member
my SBC doesn't have any pulling power in 5th gear at 140+. thinking of 3:55 instead of 3:73 to increase top speed in 4th. would like to install an ATI Procharger ,but to do that right it would take $5,000. need to work on ground effects first. T
Old 02-10-2014, 07:03 AM
  #217
pauldana
CF Senior Member
pauldana's Avatar
I have around 650hp, so pulling is not an issue, but the jump form 4-5 is way to great to be used on a race track.... it is nothing but a cruising gear... not what i wanted.
pauldana is offline
Old 02-10-2014, 07:19 AM
  #218
gkull
CF Senior Member
gkull's Avatar
Liked 353 Times in 320 Posts
With 4.11 my 434 was able to accelerate while in the .64 OD. But the jump from 4-5 sucked. with 4.11 I was shifting 4-5 @ 135-140 mph.
I installed the 3.55 rear so I could redline in 4th @160 something so I would not have to use 5th on the bigger road racing tracks. Now my 5th is just an over 70 mph freeway gear
gkull is offline
Old 02-10-2014, 12:12 PM
  #219
roscobbc
CF Senior Member
roscobbc's Avatar
So fellas - with a 3.08 rear end and 27" tall rubber theoretical top end at, say 6500 rpm would be perhaps 165/170 mph. How about the addition of an 'old school' Hone overdrive (or 'modern world' Gear Vendors O/Drive) - do we think it would 'pull' OK (in theory, naturally!)
roscobbc is offline
Old 02-10-2014, 01:02 PM
  #220
qwank
CF Senior Member
qwank's Avatar
Liked 12 Times in 12 Posts
must have been a convertible
qwank is offline
Quick Reply: How do you keep the C3 from getting light above 120mph?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
