Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C3 Corvettes, 1968 - 1982 > C3 Tech/Performance
Reload this Page >
How do you keep the C3 from getting light above 120mph?
Old 04-25-2012, 11:36 PM
  #41
pauldana
CF Senior Member
Support Corvetteforum!
pauldana's Avatar
Originally Posted by Bee Jay View Post
When I put an aluminum spoiler in front of the vents, the yarn really jumped out.
yea.... this is what got me thinking about this....
you running this hood for the Solvang trip? love to see it in person.
pauldana is online now
Old 04-26-2012, 12:26 AM
  #42
I'm Batman
CF Senior Member
I'm Batman's Avatar
St. Jude Donor '07
The C2 and C3 suffered from the same aerodynamic problem brought on by the design department - the high nose. The hood vents on the 63 were supposed to be functional for exactly that reason (replicating the Mako Shark show/race car), but they were eliminated at the last minute to keep oil off of the windshield. The guys at Jaguar probably just said to wash your windshield more often.
I'm Batman is offline
Old 04-26-2012, 12:52 AM
  #43
gkull
CF Senior Member
gkull's Avatar
I really think that Bee Jay is the only one to do comprehensive testing. My only high speed testing was in preperation was for the Nevada Silver state 93 mile open road race. I developed a fast by myself stable vette. What really threw me around to the point of feeling unsafe was being around the turbulance created by other high speed cars. You loose all down force in the wake of the really bad *** cars going by you or coming up to pass slower cars during the open test days.
I tested with some super fast C-5's back in the day and drafting got my heart rate up.
I personally never felt safe in my Vette in the early days until I put in a heavy 1 3/4 1.34 wall dom mild steel tubing, racing seat, and 5 point harness. My cage is not the best, but for stiffening
I also think that dual adjust front QA-1 coil overs with 600 -700 pound springs and running 4.0 or higher castor make a vette very stable.
My street tires are also 186 mph rated. My slicks might be very high MPH
gkull is offline
Old 04-26-2012, 01:37 AM
  #44
Kid Vette
CF Senior Member
Kid Vette's Avatar
Originally Posted by FlyLS6 View Post
But, you'll notice the vents on either side of the hood bubble, and I always thought they contributed to the stability. It'd be nice if someone made a fiberglass vent panel that could be attached to a 'vette hood on either side. It'd be interesting to see how it worked out, and regardless, it'd look cool as heck.
Here's an idea for some vents.
Kid Vette is offline
Old 04-26-2012, 01:51 AM
  #45
I'm Batman
CF Senior Member
I'm Batman's Avatar
St. Jude Donor '07
Your car certainly knows how to move!
Old 04-26-2012, 02:05 AM
  #46
gkull
CF Senior Member
gkull's Avatar
Yes, Batman I gave you a ride back when I only had a 427 wimpier motor that later broke the crank shaft and I had a 4.11 rearend without my bigger tires and wheel flares
gkull is offline
Old 04-26-2012, 02:57 AM
  #47
I'm Batman
CF Senior Member
I'm Batman's Avatar
St. Jude Donor '07
That's just scary!
Old 04-26-2012, 01:32 PM
  #48
TheSkunkWorks
CF Senior Member
TheSkunkWorks's Avatar
Location: Graceland in a Not Correctly Restored Stingray
So that other viewers are aware, IIRC there's only one source for the fully functioning wheelwell vents with splash shields; Tracy Performance. All others appear to be strictly cosmetic.
TheSkunkWorks is offline
Old 04-27-2012, 10:28 AM
  #49
oldalaskaman
CF Senior Member
oldalaskaman's Avatar
if the 'just what works ' catagory, the hood vents from a turbo charged 90's pontiac, come with drip trays that dump perfectly for a vette, fit vette fenders or hoods like they were designed for them, let air and heat out, come with all attachment hardware, for bout $80 shipped. I put them on my C4 poor mans track car , they are excellent. hope this helps.
oldalaskaman is offline
Old 04-27-2012, 11:55 AM
  #50
pauldana
CF Senior Member
pauldana's Avatar
1. I really think that Bee Jay is the only one to do comprehensive testing.
2. What really threw me around to the point of feeling unsafe was being around the turbulance created by other high speed cars. You loose all down force in the wake of the really bad *** cars going by you or coming up to pass slower cars during the open test days.
3. I also think that dual adjust front QA-1 coil overs with 600 -700 pound springs and running 4.0 or higher castor make a vette very stable.
1. seems to be so...
2. ok... another worry, was that at 120... or 160?
3. how to you feel about bilstine sports and 600# springs?
how much pressure develops under the wheel well? or negative pressure above at that point?
Old 04-28-2012, 06:31 PM
  #51
luerja
CF Senior Member
luerja's Avatar
That looks very familiar.....
luerja is offline
Old 05-05-2012, 03:34 PM
  #52
TheSkunkWorks
CF Senior Member
Just thought it worth noting the forward location of hood vents on the ZL1 Camaro...
Highly suspect the General has done a bit of research on this.
Old 05-05-2012, 04:50 PM
  #53
69427
69427's Avatar
Location: I tend to be leery of any guy who doesn't own either a chainsaw or a handgun.
Is that the production configuration? That's common on race cars for the last 50 years (I recall seeing some of the early front radiator Chaparrals dumping out the hot air there), but I always assumed the reason nobody did that for a production vehicle was that a share of this hot roasted-bug air eventually makes its way into the cowl cabin air ducts, like in the picture. Did they address this issue somehow?
69427 is offline
Old 05-05-2012, 05:08 PM
  #54
TheSkunkWorks
CF Senior Member
Apparently that's the production config. Viewing a recent segment about the ZL1 on Motorweek got me curious enough to do some followup. I'd think they're far enough ahead of the cowl that extracted air likely doesn't adversely affect cabin inlet air temps.
Old 05-05-2012, 05:16 PM
  #55
pauldana
CF Senior Member
pauldana's Avatar
That, is very interesting..... I wonder if you could make a C3 hood look good with something like that in the front middle section...behind the radiator, in front of the engine.
Old 05-05-2012, 05:31 PM
  #56
I'm Batman
CF Senior Member
I'm Batman's Avatar
St. Jude Donor '07
Is that in front of or behind the ZL1's radiator? The L88 hood always looked to me like Zora intended for it to have a functional vent, but it was probably dropped for the same reason the 63's vents were cosmetic - didn't want oily air blowing up on the windshield.
I kinda dig the fender vents.
Old 05-05-2012, 05:35 PM
  #57
another-user
CF Senior Member
another-user's Avatar
you could almost do that right now with an LT1 hood. it might take some tweaking, but i think it would be pretty close as is. ive actually thought about punching a couple holes in mine, but i just cant bring my self to do it.
another-user is offline
Old 05-06-2012, 06:44 AM
  #58
Bee Jay
CF Senior Member
Bee Jay's Avatar
You mean like this?
Bee Jay
Bee Jay is offline
Old 05-06-2012, 11:36 AM
  #59
vette427-sbc
CF Senior Member
vette427-sbc's Avatar
Ive been thinking about a heat extractor hood set up like this...
L88 hood bulge moved back a few inches and the rad leaned forward. The hood hinge mechanism will have to be modified to clear the rad when it is opened. A spreader bar would be in the way, but I think it would be Ok if it was in the airduct
vette427-sbc is offline
Old 05-06-2012, 11:38 AM
  #60
vette427-sbc
CF Senior Member
The LT1/BB hood vents are too far forward... Mine are cut out and it is just barely behind the rad support
Quick Reply: How do you keep the C3 from getting light above 120mph?
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
