69 Radiator with Auto
Old May 14, 2012 | 10:24 AM
SoCalErv's Avatar
SoCalErv
Army
Default 69 Radiator with Auto
Would someone please explain to me how the transmission is cooled via the radiator? Does the transmission oil travel through the radiator?
I ask because I have a leak from the radiator that seems to be an oily substance and all I can think of is transmission fluid mixed with a little bit of anti-freeze.
Can the radiator be pulled without disconnectiong the A/C?
Old May 14, 2012 | 10:50 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by SoCalErv
...Would someone please explain to me how the transmission is cooled via the radiator?...
There is a tank in the radiator for the AT fluid. You can see the two fittings for it on your radiator.
...Does the transmission oil travel through the radiator?...
No.
...Can the radiator be pulled without disconnectiong the A/C?
Only if you have room to work with it there.
