Water temp gauge problem.
Old May 18, 2012 | 09:36 PM
540 vette's Avatar
540 vette
Default Water temp gauge problem.
I installed a new printed circuit on my 1980 for the gauges, They all work fine except the water temp. It worked fine before I changed out the printed circuit now it seems to stay around 250 degrees. Does someone have a picture of the back of the gauge panel so I can compare it to mine.
Old May 18, 2012 | 09:57 PM
BHRIG's Avatar
BHRIG
Make sure the "nuts" attaching the terminals are making contact with the printed circuit..............
Old May 18, 2012 | 10:04 PM
540 vette's Avatar
540 vette
They are. I snugged them down. There are 4 nuts on this gauge.
Old May 18, 2012 | 10:09 PM
BHRIG's Avatar
BHRIG
I think I remember the post on the top left, as you look at the rear
SHOULD NOT make contact with the printed circuit
Remove that nut and see if your problem is solved...
Old May 18, 2012 | 10:52 PM
dinodon51's Avatar
dinodon51
False high temperature is indicative of too little resistance. Check that your 90 ohm resistor is properly connected. It should be UNDER the flexible plastic circuit board.
Old May 19, 2012 | 08:35 AM
540 vette's Avatar
540 vette
It's under it. It has to be a wrong nut in the wrong place. Everything worked before the new printed circuit.
Old May 19, 2012 | 03:03 PM
540 vette's Avatar
540 vette
I removed the nut and now it just reads 100 degrees. I tried the old board but it is screwed up where the plug goes in so that wasn't any help.
Old May 19, 2012 | 03:10 PM
...Roger...'s Avatar
...Roger...
I was thinking the positions for nuts was 12 oclock 3 and 6 looking at it from the back.
I'll see if I can find a pic at the Willcox site.
Old May 19, 2012 | 03:13 PM
...Roger...
Did you remove the 6 oclock nut,if so that explains the 100 reading ?
Old May 19, 2012 | 03:14 PM
...Roger...
See if this link works from Willcox
http://willcoxcorvette.com/popup_image.php?pID=26153
Old May 19, 2012 | 03:40 PM
540 vette's Avatar
540 vette
I removed the one at 9. The one at 6 should be there. I found a picture.
Old May 19, 2012 | 04:14 PM
540 vette's Avatar
540 vette
I have 12 volts at the top screw, 12 volts at the bottom, signal screw.
Do you nthink I cooked the gauge by putting the nut on the 9 o clock lug.
That put 12 volts to both sides of the resister.
Also when the key is on the needle moves to the left a little, as soon as you put the key on it sits at 100.
Old May 19, 2012 | 04:29 PM
BHRIG's Avatar
BHRIG
look at Rodgers' picture above....
The one that should be removed is at 9 o'clock position......
insulate the screw so as NOT touching printed circuit.
That should solve the problem.....
Old May 19, 2012 | 05:11 PM
540 vette's Avatar
540 vette
If you look at my post above I did remove the nut at 9 and insulated it so that part isn't touching the printed circuit.
The problem is still there. Do you think I fried the gauge because I had that nut on at 9.
Everything was working before I did the printed circuit. So the gauge might have cooked.
Old May 19, 2012 | 05:18 PM
BHRIG's Avatar
BHRIG
I just checked my car and with the key ON the temperature gauge IS at about 100 degrees.............start the engine and see if the gauge responds as it warms up......
I believe your gauge is working properly......
Old May 19, 2012 | 05:25 PM
540 vette's Avatar
540 vette
I tried that and it didn't move. But I only let the car run for about 15 minutes.
I will look at it tomorrow. Thanks.
Old May 20, 2012 | 12:57 AM
TimAT's Avatar
TimAT
Pull the wire off the sender and see what the gauge does. SHould go full hot. Ground it should go full cold. ( I could be backwards-?)
To Water temp gauge problem.
Old May 20, 2012 | 06:19 PM
dinodon51's Avatar
dinodon51
Ground is full hot.
The gauge registers with high resistance at low temperatures and low resistance at high temperatures. I recommend you put an ohm meter on both sides of the back resistor and confirm that you are getting 90 ohms resistance. If it's not reading you may have a loose or bad connection where the plug goes into the back of the circuit board.
Be advised that even when you get the wiring squared away the gauge is about as accurate as a hand grenade. When my gauge reads about 220 its actually 195 on the engine as checked by a thermocouple and I do have the correct temperature sensor.
Old Jun 15, 2012 | 09:06 PM
540 vette's Avatar
540 vette
I ran the car for about 30 minutes and the gauge did not move.
Old Apr 21, 2014 | 07:43 PM
ricrx7's Avatar
ricrx7
Cruising
Were you able to solve this problem? Thanks.
