69 fuse panel and mystery wires--pics
69 coupe, 4 speed, 350, no A/C, w/ electric windows.
In PIC #1, the phillips screwdriver is pointing to, in what does not appear to be standard, a plug coming out of the fuse box marked ACC. What accessory would this be?
In PIC #2, the circuit tester is pointing to two wires with connectors. I began to pull the carpet back and to '"track" the wires. They are headed toward the rear of the car. Fortuantely, nieither wire was hot. All ideas welcomed.
PIC #1
PIC #2
PIC #1
PIC #2
St. Jude Donor '08
This is the accessory connection in the 1st pic, its used to power any aditional device you wesh to add to the car, it has a 12V switched power.
The two terminals in the 2nd pic look like a speaker connection.
The tap plugged in to the ACC is your power windows trigger for the relay,the extra just provides an extra tap in case you need it for another accessory.
