Checking Power Steering Oil
I just got my 1978 SA Vette back from having the engine rebuilt. That mechanic and I have parted company,The power steering no longer works. The PS belt is turning. Do you have to remove the alternator or something to get to the power steering unit? Other things do not work but right now the PS is first on my list? if the fluid is not low is there anything else I can check myself (I am about a one on a wrenching scale of 1 to 10)
It was a pita. I managed to get the lid off and there was no power steering fluid in the unit. Bought some power steering fluid and fabricated a long nose funnel until it fit well enough to fill the reservoir. Of course, I managed to over fill it and got the pleasure of cleaning up the mess. Thanks guys.
Geez.. Just loosen the alternator, remove its belt, then pull it outward. Voila'! Now you can get at the P/S cap. Buy a long-neck funnel if you need to add fluid; but do it slowly, as that type funnel takes a while for the oil to get to the bottom. For as infrequently as you need to service the P/S pump, loosening a couple of 'exta' bolts is not big deal. But, if you need to remove the pump (unlikely that the pump is the 'problem' with P/S non-functional), it's best removed from below.
My suggestion is that you spend your spare time, this week, rounding up a new mechanic. Call some car clubs in your area...Corvette club if there is one there. Make a list of possible mechanics that have knowledge on C3's/Corvettes with some names of their customers that you can contact for their assessment of skill level, quality of work, and their usual costs (labor rate per hour). There are always good folks around. It's just difficult to find them at first. But, with you owning a C3 and being a 1.0 on mechanical capability, you really need to find a good "go to" mechanic for those things you choose not to do.
P.S. Whenever you have work to do on your car, check on the Forum for advice on how best to go about it...even if you find a good mechanic. There is a lot of experience and wisdom here that can help you make good decisions on the best and least expensive way to get stuff done on your car.
Some folks who frequent 'Forums' are looking for help. Some other folks do their best to 'try' offering assistance. Other folks are just a PITA and are relatively useless participants on a Forum [and they know who they are!].
When I first found the Corvette Forum, I was someone in need of that help/knowledge. The CF was a great source of information for me and helped me learn a great deal about the C3 and its nuances. That info...combined with working my @ss off for about 5 years in every system on this car...provided me with a working knowledge that I now choose to use in helping other folks who "come calling". Hopefully, some of that stuff is helpful to others.
whoever at GM came up with that brilliant alternator mount needs beat about the head and shoulders! it's far from user friendly!
