Motor Oil "Wear Test" and "Lab Test" Data
#301
I use some of his top oils, and they are factory fills by more than one manufacturer. I don't think they would spend the time to explain their reasons. It sure would be interesting if they would. Ron B.
#302
Thanks for your write-up, I was looking for some discussion on the timing for oil changes since I've heard that with the newly advanced synthetics you can extend intervals up to a year. However there are lots of variables to consider. How well does just eyeballing it work, if it looks dirty change it? If it does look dirty I would think it's time to change with the only danger being possibly the viscosity of the oil could have broken down even when it still looks on the cleaner side yet. I don't know as that would or could happen using a modern full synthetic though.
#303
High film strength is an advantage but only one of numerous factors that determine long term wear prevention.
Take this information as it should be taken. an accurate study and list of the film strength breaking point of new oils at operating temperature but DON'T bet your race motor on an improperly drawn conclusion that film strength alone will protect that critical lobe/lifter interface because it can't and it won't.
The following 2 users liked this post by 63mako:
68post (08-12-2017),
mr.beachcomber (08-26-2017)
#304
So do a test as you described and let us know the best oil. I want to know, not just repeat what you have heard. Thanks Ron B.
#305
The oil color isn't really helpful, for instance my diesel oil looks black as soon as I change it. A big problem is viscosity changes due to fuel dilution in some situations. The TBN number is also important as it keeps oil from going acidic. I like high TBN number oils because they have more of a buffer.
I've got 3 cars I've had over ten years, some I've put close to 200k miles on. It works for me, I have enough routing maintenance to do on Saturdays without wasting my time changing oil needlessly.
Just my .02 worth
#306
Amsoil is the only company I know of that publishes independent lab test results and compares their oils against others. When I was doing the research years ago, I was satisfied they were the best overall oil for my needs. Are there other excellent oils out there? Sure, but my recommendation would be to stick with a PAO/PE based synthetic. The rest is up to the manufacturers additives, which do vary.
I used to subscribe to an oil tribologists newsletter. The truth is the subject is very complicated and not easily "blogged" about. It helps to have a solid chemistry background.
#307
#308
For what it's worth.. for those that know me..
63mako is dead nuts, 100% correct...
Hey.. but don't believe me or mako.. go right ahead and put a low zink oil in your new flat tapped bad *** build, and build it again in 1000 miles:-)
And I'll laugh my *** off.... because you have been warned..
Good luck with that..
Peace.. pauldana
63mako (07-29-2017)
#309
What do these comments mean?
I understand #3, once you get to 1000ppm anything more only prolongs protection. But what do statement #1 and #2 mean? How is more zinc damaging?
1. Well known and respected Engineer and Tech Author David Vizard, whose own test data, largely based on real world engine dyno testing, has concluded that more zinc can be damaging, more zinc does not provide today's best wear protection, and that using zinc as the primary anti-wear component, is outdated technology.
2. The GM Oil Report titled, "Oil Myths from GM Techlink", concluded that high levels of zinc are damaging and that more zinc does not provide more wear protection.
3. A motor oil research article written by Ed Hackett titled, "More than you ever wanted to know about Motor Oil", concluded that more zinc does not provide more wear protection, it only provides longer wear protection.
68post (08-23-2017)
#311
It's utter madness to put faith in "test" results posted on the internet without any way to verify the tests were done accurately. Personally, refusing to submit to any kind of peer review tells me that there is an ulterior motive behind these posts.
#312
He's trying to use the data out of context. He's trying to use it to prove that the zinc content doesn't matter. The data actually says that a certain amount is required for protection, but too much starts to cause damage. Somewhere >2000ppm could start to be damaging, but I haven't looked for any data which goes into much detail on how much damage or how fast the damage occurs.
#313
This isn't even true without a peer review of the test method.
#314
One thing that would be helpful is since talk about flat tappet protection depends somewhat on spring pressures, maybe including some spring pressures and how much zinc would be a good idea.
Something like:
xxx lb - light pressure, aaaa ppm ZDDP needed
yyy lb - moderate pressure, bbbb ppm ZDDP needed
zzz lb - heavy pressure, cccc ppm ZDDP needed
Yes, ti says we need at least 1000 ppm, but then it is mentioned in several locations you can get away with less with light pressures and slow easy ramps, but need more with heavy pressures and aggressive ramps. But what are we really looking at on pressures ramps?
Something like:
#315
I've honestly never seen, nor even heard of an engine blowing it's guts out based strictly on the oil.
Yeah, I know, "flat tappets and zinc". I ran plain 10w30 Valvoline in my solid lifter Pontiac RAIV engine. It's still running after being built in 2000. I checked valve clearance 8 years ago, and they were perfect. Comp Cams.
So, I stopped worrying about oil. Pick any oil anywhere near the top of 540 RAT's list, and you should never have an oil worry, ever.
#316
#317
I've heard core issues being a problem, too.
Pick one of the top oils that has decent zinc/phos if you want to run a flat tappet cam.
If I were to build the same engine, I'd go roller and gain 40hp.
#318
Yessir, from what I've read it looks like bad cores and no zinc in break-in oils have both been an issue for flat tappet cams. And I agree- doing a fresh engine would include a roller cam for me too. The sarcasm was only intended to make a point, not to be too biting. Apologies if it came across too strongly.
AirBusPilot (09-08-2017)
#319
The following 3 users liked this post by 63mako:
