hood on 73
Old Jun 28, 2012 | 12:14 PM
JER BEAR's Avatar
JER BEAR
Default hood on 73
just got car done after 2 years off frame, went to put hood on work well twice when i shut it but 3rd time driver side releases pass side won't not sure how to get it back open any helpful ideals
Old Jun 28, 2012 | 12:31 PM
BlowAMouse's Avatar
BlowAMouse
Do not know if this will help but it just happen to me while putting mine on last week (also a 73),
If the cable that goes from the left (Drivers side) side release to the right side is not broken (take a flashlight and CAREFULLY lift the hood to look for it).
Then you can CAREFULLY pull the driver side of the hood up and reach in with your finger and move the release latch forword to unlatch the other side.
If your cable is broken, hopefully another member can help
Sorry no pictures here.
hope it helps - good luck
Old Jun 28, 2012 | 04:41 PM
'75's Avatar
'75
If the cross cable is loose, the left side will release, but not the right. Try pushing the left side down an then pull the release all the way.
To hood on 73
