My header install went well.....
Perhaps it was because I read so many other experiences that mine went so well. It also worked out well because all of the bolts on the old exhaust - which i expected to have to fight all the way came right out with no complaints.
If you have never used it, I heartily recommend Aero-kroil as a penetrating lubricant - I sprayed this stuff around where the cast iron intakes mated with the heads and it soaked right on through to the bolts.
Here is what needed to be done to install these headers, after the removal of the existing exhaust.
driver side:
1. remove alternator
2. remove Z-bar
3. remove spark plugs and drape wires out of the way
Passenger side
1. remove A/C compressor and bracket
2. remove starter
3. remove spark plugs and drape plug wires out of the way.
Once this was done the car was lifted about 8-10 inches and placed on 4 jackstands - 2 behind the engine compartment and two up front onto the sway bar bushings.
Both headers installed from below with NO problems - in fact We had both side mounted on the car in 25 minutes after the car was raised.
While the Z-bar was out it was degreased and painted with rallye wheel silver - which is a very close match for the jet hot coating on the headers. in the image below you can see the hedman hedders provide ample clearance to the steering box.
We did have one problem - during the reinstall of the starter we noticed that the header was touching the Idler arm - we removed the header and dimpled the tube in that location.
All that remains is some welding to complete the dual exhaust install - I am still waiting on replacement calipers from VB which is why I started all this.
[Modified by fauxrs, 3:08 PM 5/27/2002]
[Modified by fauxrs, 3:09 PM 5/27/2002]
Mark B.
:cheers:
Eddie
