Alignment on a '76
Alignment on a '76
Hello,
I noticed that the insides of all four tires on my '76 were nearly completely bald, while the outside of the tires still had plenty of tread. I assume this is an alignment issue.
I'm a little concerned If I take the car to an "alignment shop," that they are going to come back with a laundry list of repair items or items that need to be replaced without me really understanding what parts are involved in that project.
I know my car also needs a suspension rebuild. Just curious if the two jobs require replacing many of the same parts, or if I should tackle each separately.
I guess I'm Not sure where to begin...
If I should handle the alignment as a separate project, can you tell me what parts should be replaced? Along with the "while you're under there..." parts as well?
Thanks in advance for your comments and suggestions. Sorry is my question is too vague. I'm fairly inexperienced at working on my car. I've been learning with every project and this forum is an awesome resource for assisting a "rookie" Vette owner.
Alignment on these older cars is something that can scare the new mechanics. The best thing to do is to find a place that knows older cars. Order the parts that you will need, including spacers. They likely won't have this stuff at a local shop.
Are you replacing springs in your suspension? If you are doing springs and other major components then do that then get an alignment.
If you are only doing shocks then get your alignment done right away.
