revised: help needed identifying vac advance can specs
Thanks Lars and Scotty. I failed to mention that this is not the stock distributer - it is an Accel unit that takes the longer reach "arm". The engine is not stock either and I want to set the initial at 14* with 16* vac advance at 12". Cruise manifold vac is 15". The VC1765 has the advance I want but the short reach arm, so the parts guy said the VC301 had the same specs but the longer arm I need for this distributer.
Thanks again.
Thanks again.
Cannt tell from this what the prior exchange was but if you are using an Accel distributor, and there appear to be quite a few to chose from for your application, how will a vacuum advance can for a Delco distributor fit?
Thanks again.
Thanks again.
Well, once Lars sends you his paper on vacuum advance control units, go down toward the end of the paper and check out the HEI control units. I think you will find that the VC1853 has very similar specs to the VC1765.
Keep the shiny side up!
Scott
